Wheel bearing problems
Old Aug 28, 2017 | 08:02 PM
68bigblock's Avatar
68bigblock
Default Wheel bearing problems
I purchased a new spindle set up tool to redo my 68 corvette wheel bearings. I also purchased a shim and spacer kit that came with 9 different size shims. Here is my problem. When I set the tool up with the bearings, shim and spacer, I have no play before I add any shims. What do I suppose to do? Put in the smallest shim? I have a dial gauge and it shows zero movement with no shims. Confused.
Old Aug 28, 2017 | 08:25 PM
'75's Avatar
'75
More shims give you clearance. Add shims till it's too loose, measure the end play and subtract accordingly.
Old Aug 28, 2017 | 09:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Without the shims you won't have any play..
So pick one in the middle for a place to start, then check your end play... and like Bill said.. make changes accordingly. I try to shoot for 3-4 thousandths run out... I've always set them up this way and in all the years I've been in business I've never had one come back.
Willcox
Old Aug 28, 2017 | 09:13 PM
cagotzmann's Avatar
cagotzmann
Are you sure ?
I had a similar problem, the new Large spacer was bigger and with no shims the bearings where to tight. I took the large spacer to a machine shop to trim it down so I could add 1 shim to get 0.001 end play.
Am I reading you info correct. You add shims to make up space (tighten) remove shims to loosen / add more end play.
Old Aug 28, 2017 | 09:16 PM
'75's Avatar
'75
Originally Posted by cagotzmann
Are you sure ?
End play means looseness. More shims between the bearings makes it looser, more end play.
Old Aug 28, 2017 | 10:04 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
What he said ^
Old Aug 28, 2017 | 10:10 PM
cagotzmann's Avatar
cagotzmann
Yea that is correct add more shims moves the bearing away from the race and more end play
I had the main spacer shortened so I could get the required end play
I had too much end play with no shims
How soon I forgot this horrible job replacing the rear bearings
Old Aug 28, 2017 | 10:12 PM
vette_jim's Avatar
vette_jim
And beware of aftermarket junk, the shim size I needed was off .002 around the circumference. Drove me nuts until I figured out what was going on. Every time I spun the assembly, the endplay measured differently. I had to take a larger shim that was true and mill it down to the size I needed.
Old Aug 28, 2017 | 10:19 PM
0Willcox Corvette
Former Vendor
I can cheat if needed, I have a lathe... If I can't get 3-4 then I can always spin the spacer up in the lathe and make an adjustment to obtain the clearance I want... but that doesn't happen very often, in fact I can't tell you the last time I had to do this.
But.. as stated above.... No shims means no clearance... Add shims until you get end play then adjust appropriately.
Willcox
To Wheel bearing problems
