Another cooler intake air tale :)
Old Oct 4, 2002 | 09:52 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
Default Another cooler intake air tale :)
I was just out in the garage checking timing and connections...generally just doing simple maintanence. The 72 was idling and when I went to turn it off I noticed that the air/fuel gauge was hovering between 14/1 to 13.5/1. It usually shows about 12.5/1. The difference is...the hood was up. I closed the hood and two minutes later the gauge showed it's normal 12.5/1 at idle. Cooler air does make a difference. :) One of these days I will get a cowl induction hood. :cheers:
Old Oct 4, 2002 | 10:19 PM
Aaron76's Avatar
Aaron76
Default Re: Another cooler intake air tale :) (AlwaysWave)
That's pretty cool info
I know its a little off topic but how do you hook up an air/fuel gauge
Old Oct 4, 2002 | 10:27 PM
AlwaysWave's Avatar
AlwaysWave
Default Re: Another cooler intake air tale :) (Aaron76)
all the info is here.http://autometer.com/
I put the gauge in place of the clock.
To Another cooler intake air tale :)
