1970 454 cooling help needed
Old Sep 3, 2017 | 01:04 AM
RussellD's Avatar
RussellD
Default 1970 454 cooling help needed
Can anyone tell me what electric fan set up to use for a 1970 corvette with 454 that has air conditioning also.do t want the most expensive but not necessarily the cheapest either.just want one that's the simplest and most effective for the money.
Old Sep 3, 2017 | 08:15 AM
Rayhawk's Avatar
Rayhawk
Dewitts has an excellent dual fan/shroud setup.
Since you have A/C, make sure you add a 3rd relay that will turn fans on when A/C is on.
Old Sep 3, 2017 | 11:59 AM
RussellD's Avatar
RussellD
What are the actual temperatures you should stay within to be within GM specifications?
Old Sep 3, 2017 | 01:59 PM
The13Bats's Avatar
The13Bats
Whats wrong with the factory mech fan and if you really need it add a smaller electric fan out on the ac condensor.
There is a lot of work including upgrading the charging system to run electric fans up to par with cooling a bb with ac...
To 1970 454 cooling help needed
