1970 rear snubber bracket destroyed
Old Sep 5, 2017 | 08:09 PM
sboying's Avatar
sboying
Default 1970 rear snubber bracket destroyed
anyone know where I can order the bracket, would prefer this vs cutting one off another rear end.
thx
Shawn
Old Sep 5, 2017 | 08:48 PM
Duntov's Avatar
Duntov
The bracket bolts to the differential and then has a rubber bushing to the frame. If you broke the differential one, eBay. If the one that attaches to the frame maybe eBay, contemporary corvette, or Dinos corvette salvage.
Old Sep 5, 2017 | 09:00 PM
sboying's Avatar
sboying
thx found one: http://www.parts123.com/corvettecent...50g&ukey=20184
Old Sep 5, 2017 | 09:25 PM
TCracingCA's Avatar
TCracingCA
Ouch how the heck did that happen?
I cant see how the existing can't be welded up or fixed! Unless it rotted off from rust somehow! Maybe someone was drag racing and put a Ford 9 inch or something back then? If you have a car for reference and can weld, it shouldn't be a difficult repair with the diff out!
Old Sep 5, 2017 | 09:33 PM
sboying's Avatar
sboying
rear-end is out of the car for half shaft seal replacement at the local corvette shop. he called me and I looked at it, cried but soon got over it. Not rusted out just torn and mangled. Actually prob a good thing this was found sooner than later. I had just replaced manual trans mount which had separated. After this fix I'm done for awhile...
Old Sep 5, 2017 | 10:42 PM
TCracingCA's Avatar
TCracingCA
I have seen some butchering, from an old rusted up bolt that someone could remove! Sounds like you have it handled!
Old Sep 6, 2017 | 01:36 PM
redvetracr's Avatar
redvetracr
need a NOS GM snubber to go with that new pinion mount? I have one...send a PM if you or anyone else is interested.
Old Sep 6, 2017 | 02:32 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This typically happens when a poly bushing is run in place of the stock rubber. I've repaired this many times over the years where the bracket actually rips away from the crossmember.
I have some used brackets here, but for the OP, it's probably best to just get new.
Willcox
Old Sep 6, 2017 | 02:54 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I run mine a "little" hard sometimes. My Dana 60 IRS setup bolts to stock mounts. I was using a poly bushing and found that it had punched through the frame bracket like a whole punch! Perfectly round cutout.
I made a new frame mount out of 3/16" steel.
JIM
Old Sep 6, 2017 | 03:55 PM
0Willcox Corvette
Former Vendor
JIM
Even if you just drive them a little hard they'll still do this with the poly.
Willcox
Old Nov 12, 2017 | 09:45 PM
sboying's Avatar
sboying
had the local corvette guy fix this. Man it was mangled. He removed a bracket from another rear end in good shape and welded on. turned out great, got rid of some clanks and rattles I was hearing. I went and look over everything while it was apart, diff gears looked great. Thx for posting.
To 1970 rear snubber bracket destroyed
