whats this??
Old Oct 5, 2002 | 02:08 PM
OkeeGuy's Avatar
OkeeGuy
Default whats this??
what is this bracket beside the steering column? (below the brake booster)
Old Oct 5, 2002 | 02:20 PM
tworottiedogs's Avatar
tworottiedogs
Default Re: whats this?? (SIGNGUY)
I asked the same thing some time ago. It is where the spring goes for the z-bar. My spring was going to the motor mount (bubba). Now, it has the correct springs going to the bracket.
I think I am looking at it correctly. I see your spring going to the other side of that bracket. I may have mine on wrong??
[Modified by tworottiedogs, 1:21 PM 10/5/2002]
Old Oct 5, 2002 | 02:30 PM
trw's Avatar
trw
It is for your interlock cable. The cable runs from your reverse lever (on the trans) to the steering lever. You should have a lever a couple of inches above the hole in that bracket. The cable is held through the hole with a "C" clip.
If installed, it makes you put the car in reverse before you can get your key out. It also will not let the car out of reverse without the key in. Another anti-thief thing.
this seems to be one of the first things people undo. Pain to put car in reverse to shut it down.
Terry
[Modified by trw, 10:33 AM 10/5/2002]
Old Oct 5, 2002 | 03:31 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: whats this?? (trw)
yes for the shift interlock cable to run through.
Old Oct 5, 2002 | 05:30 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: whats this?? (pats406nitrovette)
but mine is a 4 speed...not an automatic...??
did they just put them in all bodys "incase" it was to end up an automatic??
Old Oct 5, 2002 | 05:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
http://temp.corvetteforum.net/c4/eddie_96//dsc00020.jpg
Signguy, this is the cable you should have with a four speed car. This area will soon be refinished. It looks really crappy compared to yours.
Disco_Mike's Avatar
Disco_Mike
my 79 L82 4speed has it also. i dont know what it is but it might be used the the kick sown shift linkage for autotrans. just a guess on my part.
by the other posts, guess i was way wrong :crazy:
[Modified by Got79Fever, 10:08 PM 10/5/2002]
Old Oct 5, 2002 | 05:46 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: whats this?? (Eddie 96)
ok...cool...thanx...
mine dosnt have the part on the steering column...apparently an owner before me didnt like it there or something???
i guess ill just remove it when i refinish my engine bay which will be real soon...
thanx for the compliment about mine but it looks really crappy under there...it looked pretty good til i degreased the area and now it got so clean that all the dirt and grease is gone and some bare metal is showing...
that project begins this week... :)
[Modified by SIGNGUY, 4:49 PM 10/5/2002]
To whats this??
