Tranny Gear Oil
Old Oct 5, 2002 | 08:31 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Tranny Gear Oil
I found a quart of Mobil 1 75w90 left over from the rear diff changeout and was wondering if this will work in the manual transmission on my 70.
Old Oct 5, 2002 | 08:35 PM
Jvette73's Avatar
Jvette73
Default Re: Tranny Gear Oil (Eddie 96)
Mobil 1 is good stuff. As long as its correct weight for the application I'de use it in a heartbeat.
Old Oct 5, 2002 | 08:36 PM
Eddie 70's Avatar
Eddie 70
Default Re: Tranny Gear Oil (Jvette73)
Oops,I guess I should have asked what is the correct weight also.
Thanks for the reply.
Old Oct 5, 2002 | 08:39 PM
Jvette73's Avatar
Jvette73
let me check my manual...be back in a few..unless someone beats me to the answer
Old Oct 5, 2002 | 08:46 PM
Jvette73's Avatar
Jvette73
My book says SAE80 or 90W so what you have covers all that. I think is a go.
Old Oct 6, 2002 | 10:33 AM
Eddie 70's Avatar
Eddie 70
I guess I will use it and see how it works.
Old Oct 6, 2002 | 10:38 AM
Jvette73's Avatar
Jvette73
Yeah that 75w90 will cover a broad range of applications. Mobil1 is good stuff. Ide dump it in there without a worry. By no means am I an expert at this though. Kick back and see if someone else may caution you. I doubt it will happen though.
Old Oct 7, 2002 | 09:26 AM
norvalwilhelm's Avatar
norvalwilhelm
Just a warning to guys with modern overdrive transmissions. They do not use gear oil. They use automatic transmission fluid and if you make a mistake and install gear oil kiss the trany good bye.
They have small needle bears that are not lubed if gear oil is used.
Old Oct 7, 2002 | 09:51 AM
Eddie 70's Avatar
Eddie 70
Default Re: Tranny Gear Oil (norvalwilhelm)
Mine is the original 4 speed. Thanks for the warning though.
Old Oct 7, 2002 | 01:12 PM
Blackened 79's Avatar
Blackened 79
WHERE IS THE DRAIN/FILL PLUG ON THE TRANS...SOUNDS LIKE MY
NEXT MAINTAINENCE PROJECT (JUST CHANGED THE DIFF FLUID..
MAN WHAT A DIFFERENCE !) :D
Old Oct 7, 2002 | 05:35 PM
Eddie 70's Avatar
Eddie 70
Default Re: Tranny Gear Oil (Troublemaker 71)
The drain and fill plug are both located on the passengers side of the tranny. The lower one is the drain plug. The top is the fill plug. You can pull the top plug to aid in draining. Refill through the top plug. Refill to the top plug like at the rear diff.
Old Oct 7, 2002 | 09:23 PM
wayne_69_427's Avatar
wayne_69_427
The owners manual tells you to use SAE 80 or SAE 80-90 Multi purpose gear lube. I had used the Synthetic 75-90 in my M-21 and had problems down shifting. The gear oil has to be heavy enough to slow down the gears for the shift. I went back to the old standard 80-90 and it took the problems away. Stick with what works.
Wayne
Old Oct 7, 2002 | 09:31 PM
wayne_69_427
ps: I did use the synthetic gear oil in the diff and it works great. I use Castrol products and I did check with their tech department and they said to use regular gear oil for the trans and synthetic for the diff.
Wayne
Old Oct 7, 2002 | 10:58 PM
Stingray1970's Avatar
Stingray1970
I use it in my 70, the transmission shifts easier and smoother. It made a significant difference shifting from neutral to first
To Tranny Gear Oil
