Help me build a 509ci Big Block
#41
You need to concentrate (pay closer attention) on the cam spec choices when you're working with two different platforms. You'll need an entirely different cam profile between a 4.250" bore platform and a 4.500" one.
We have numerous 250*+ @ .050" intake lobes (hyd-rollers) peaking at 6100 with well over 700 HP and 700 Torque. We've been at 740+ with under 10:1 for years now utilizing the 4.500" bore on hyd-rollers. Most peak at 6100. We find the heads we use are the "key" part on these particular builds. I would expect a "shorter-stroke" build to be in the 700 HP area with a bit less Torque maybe!
On a side note, a good example of the benefit of using larger bore units began showing up back in the '60's when you had many mfr's using 4.300"+ bores with strokes in the 3.500" range and winding up with some serious Torque numbers back then. HP was good but the Torque was considered outstanding for back then. Gas mileage (at that time) was also a non-issue, but you didn't buy anything like these if you were interested in mileage still!
I'll say it again here, 4.500" bore platforms simply want AIR and FUEL, and a lot of both!
Thanks, Gary in N.Y.
P.S. Talking still "streeter's" here, if we lay out a program with any customer and "gas-mileage" does come up, we recommend NOT using the 4.500" platform, stay on the 4.250" bore, it will use less fuel in an "apples-to-apples" (so to speak) build.
#42
no t to hijack this thread but just wondering if you have tried any of the Crane shelf grinds, they offer .630 lift or so with similar durations as the Isky. I have also heard it said they use milder lobes that rpm well too. I think "Big Joe" has said he used their stuff on sbc with good success/rpm/stock roller lifters. Any specifics on the VooDoo valvetrain, stem diameter, hollow stem, +.100 length etc? Thoughts on using a limited travel lifter?
I have not tried those, but the extra lift would be a good idea if it revs. The voodoo test was 2.190/1.880 11/32 with several lifters including Comp short travel lifters. I will have to try those Crane lobes, thanks.
#43
Received 3,043 Likes
St. Jude Donor '05
OP little more radical than you want...just to get ya motivated
http://www.chevelles.com/forums/13-p...er-idling.html
no low ent tq problems here
#44
Dr. Detroit
Received 3,892 Likes
This guy knows a lot about BB chevys, the only thing I may disagree on is his cam choice as I always ere on the side of caution, and go a little bit smaller. I would keep it in the 240-250 range@050 and have as much lift as the heads will allow, but definitely over .600 at least.
I tend to cam big on the large bore stuff because it likes it.....and of course this should only be done if the heads are sent out and had a program put on them......
You can cam these small as Vortec and Century say....but you are spending the money so why not make it nasty? These 4" stroke engines make torque everywhere anyway......
Two different schools of thought I guess.....the smaller cam stuff will surely be smoother on the street.......
FYI.....the Brodix BB-Xtra O (Brodix calls it the "race oval") is the baddest head I have ever screwed to a BBC.....I wonder if M2 has a Program to take the heads the OP has and make them into this....if it is even possible....
Vortec is correct about valve angles......they are critical for proper low lift numbers......
Anyway...it is your 509....do it how you see fit
Jebby
#45
Funny you guys should mention Crane.... I've always wanted to run a Crane Cam, but I never have. They have a few nice hydraulic roller lobes in the .359, .365, and .372 lobe lift range (.610, .621, .632 gross valve lift). The .200" lift duration numbers look good on these lobes as well. My understanding is that these lobes are used extensively by Mercury Racing in offshore boat engines and have an excellent reputation for being easy on the valvetrain. Even their shelf grinds with these lobes look pretty good. They make 110 and 114 LSA versions. I might opt to go a bit tighter LSA and and close the intake valve sooner.
#46
I looked hard at the 298cc RR BB3-Xtra O. Killer heads. At the end of the day, they really deserve a solid roller and a big single plane manifold. The other nice thing is the exhaust port is still very close to stock on these. I don't think the 'As Cast' Race Rite can be CNC'd using the Brodix in-house program. I think they start with a different casting.
#47
#48
#49
You make a good point on the extra lift, those heads will like that. BUT when the hyd roller lobe gets more aggressive (short duration lots of lift) they do not like to rev. Example: .714 lift, big heads, 6200 RPM peak, how could I be happy with that when my GM 049 oval port 496s peak @ 6200 RPM with a 238 @ .050 hyd roller that doesn't tear anything up, I had that 239 @ .050 lunati voodoo on the dyno, peaked @ 5800 RPM @ 6100 it was down 90 HP, I was pissed, I tried every spring lifter combination known to man.........same results, I couldn't get that junk out of there fast enough, a wasted week on the dyno.
#50
no no, really thank you. Anytime some of you battle proven guys are willing to divulge results from testing you have performed its to our benefit. I know I wouldn't have the time or money to try and figure something like that out and be left scratching my head why it's a POS up top! I like the look s of that VooDoo too, for a shelf grind it's what I was actually looking too if I didn't have one custom ground.
#51
Not sure what the end goal is here but I like to drive mine with the AC on and have reasonable rpm on the highway. I run 308 gears in the rear, and loosen the converter 400 rpms from stock if it is a automatic, and it will still destroy the rear tires.
If I was going for ultimate power with no regard to street ability and comfort, I would put a bigger hood on, so I could run a better intake, ditch my factory (ported) exhaust manifolds for headers, and run quite a bit bigger of a cam, but 600 fairly mild horsepower is a nice package, and it looks completely factory under the hood.
#52
Received 1,877 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It's a longer stroke combo with larger heads (555" and Dart 335's), but a few years ago I did a bunch of dyno testing with various carbs, intakes and cams......solid flat tappet, solid roller, hyd roller, hyd roller with solid roller lifters, dual plane, single plane, BIG single plane, 4150 carbs and Dominators. HP ranged from 740-850 with same shortblock and heads.
The hyd roller was a Crane 254/258 with a 112 LSA. It used 1.8 intake rockers and 1.7 exhaust. Seems like it ended up with .720/.680 lift. It peaked HP around 6300-6400 and rev'd clean to 6800 or so with Crane Hyd lifters. With a Dominator and Super Vic intake it broke 800 HP. 760'ish with a 1000 HP and a ported Vic Jr intake.
JIM
JIM
#53
I'm starting to think about camshafts for this build. I will likely go custom, but the Crane PN139781 hydraulic roller caught my eye:
Adv Duration @.004: 306/318
Duration @.050: 244/256
Lift (1.7 rocker): .632/.632
LCA: 110
Ideally, I'd like to close the intake valve a little bit sooner, but I don't think I want to add any more overlap by closing up the LCA with these particular lobes. This cam has very stable lobes and is well-proven in endurance marine applications. The intake/exhaust duration spread is about where I want it for the Brodix heads. This grind comes standard with a cast-iron distributor drive gear as well. What do you guys think? If I go custom, I'd probably shorten the intake duration a bit and put the LSA on a 107 or 108.
LCA: 110
#54
LCA: 110
LCA: 110
#55
JIM
JIM
#56
I stopped by the machine shop today and they had bored and honed the block, balanced the crank, hung the pistons, and fit the new rod bolts. Next is to check deck height and deck accordingly.
#57
Dr. Detroit
#58
It turned out nice I think. I decided to leave it external balanced. I've got an expensive external balance flywheel on my 468 that I really wanted to reuse. The new SRP pistons are lighter than the old TRW/Manley pistons and they had to remove just a bit of material as a result. The picture shows the two new balancing holes towards each side of the counterweight. I'm trying to keep the budget reasonable in this project and I'm ok with external balancing with the target HP and RPM range this thing will get used in.
#59
Dr. Detroit
Kudos to you....nice build.
Jebby
#60
Alans 496 was built years ago, since Alans 496 was built I developed the exhaust port of the 049 head, this resulted in 670 plus HP and 6200 RPM peaks. My peanut port 467 with the Isky 228/238 not the 238/248, peaked @ 5800 RPM 585 HP, @ 6400 had 570 HP, and is run 7000 RPM through the lights. Just my experience.
She still runs though...
Hell it has been 8 or 9 years ago we did that thing.
