Looking for 1970 engine pics with chrome ignition shielding installed.
Old Oct 6, 2002 | 12:25 AM
Bugster57's Avatar
Bugster57
Default Looking for 1970 engine pics with chrome ignition shielding installed.
I'm looking for pictures to show the ignition shielding on a 1970. We go a box with all the parts (I think) and not sure how it all goes together.
BTW - a descripition of install would be really helpful.
Old Oct 6, 2002 | 01:59 AM
NHvette's Avatar
NHvette
Default Re: Looking for 1970 engine pics with chrome ignition shielding installed. (Bugster57)
Here is my 75 - I think it is very close.
http://webpages.charter.net/davekimt...ges/engine.JPG
The '70 has a two piece center section - with a top that hold down with 3 screws.
:seeya
Old Oct 6, 2002 | 06:39 PM
Solidlifters
Big block or smallblock?
Old Oct 6, 2002 | 06:55 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Looking for 1970 engine pics with chrome ignition shielding installed. (Solidlifters)
The 70 has sides that go with it. Plus the legs that go down the side of the block.
Here is my upper portion only.
Old Oct 6, 2002 | 09:33 PM
Bugster57's Avatar
Bugster57
L46 small block
Old Oct 6, 2002 | 09:46 PM
vett70's Avatar
vett70
:nopity Please send me an email if your able to get some pics. I took my shielding off 4 years ago and as soon as I fix everything else I gotta get it back on...only thing is I can't remember,either!
Old Oct 7, 2002 | 12:50 AM
Barry's70LT1's Avatar
Barry's70LT1
If you are concerned with being factory correct.
Midway thru 1970 GM changed the sheilding to the '71 and up sheilding.
Mine was built in June and has the '71 style.
Old Oct 7, 2002 | 01:54 AM
Juliet's Avatar
Juliet
Default Re: Looking for 1970 engine pics with chrome ignition shielding installed. (Barry's70LT1)
The transition was around serial number 12,000 for the ignition shielding in 1970. You might also check out the 1970 Registry website. Many of the members have webpages of their own with lots of photos of their babies. :) ~Juliet
Old Oct 7, 2002 | 08:37 AM
RMVette's Avatar
RMVette
Mine was also a late build and has the '71 shielding.
Old Oct 14, 2013 | 01:05 PM
egon48's Avatar
egon48
Iam looking for some pics too,I have a 70 L46 all the shielding is on except for the 4 pieces that are by the exhaust manifold ,2 on each side ,
Old Oct 14, 2013 | 01:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
This thread is 11 years old. Pics of the plug shields may be difficult to find since you cannot see the plugs or the shields too well with the engine in the car. Order the 1970 assembly instruction manual (AIM). The AIM shows the installation of all of the ignition shielding and lists the original part numbers for everything.
Old Oct 14, 2013 | 02:19 PM
Revi's Avatar
Revi
Depending on the VIN of your car you could have a few different variations of shielding. (Even though pic shows 75-E77, a lat 70 L46 would basically look like this.) My 70 L-46 VIN 9516 has the one piece distributor box with lid and all four of the sparkplug shielding installed.
The shielding that went over/around the distributor started out as a two piece unit with a lid, it then went to a one piece unit with a lid, and the final version was just an extended lid.
While all cars had the (non-chromed) heat shields between the sparkplug and exhaust manifolds, the early cars have chrome shields that cover the spark plugs in pairs (cyl 1-3, 5-7, 2-4, 6-8), later cars only had the chrome shielding over cyl. 5-7 & 6-8.
Old Oct 16, 2013 | 07:12 PM
egon48's Avatar
egon48
Default Ignition shielding pictures
There is plenty of drawings avail.but no real pictures of the side shielding below the exhaust manifolds,everybody took them off because it was a major pain to change the plugs.Theres plenty of pics of the dist.coil and wire shields.
Old Oct 10, 2015 | 06:35 PM
chrissy t's Avatar
chrissy t
do you still need pictures? I just installed my shielding and can take pics. I need to know how the vertical shields mount at the bottom of the motor if anyone can help.I have early 1970 with 2 pc distributor cover.Good luck, Rob
To Looking for 1970 engine pics with chrome ignition shielding installed.
