1115287 Ignition Coil
On Feb 2017 I rebuilt the distributor with new bushings, shaft, tach drive button, points, condenser, springs, etc...
When putting the distributor back into the engine I noticed oil coming out of the top of the coil. Great.
So I order a new ignition coil. When it arrives it is an AC Delco U505. The older unit has 503 stamped on it. Not thinking much about it, I put in the new coil.
Everything started right up. However, since that time, the engine seems to load up(get rich) at idle and continues to feel rich unless I rev the engine up a bit to clear it out. Then it runs just fine until the next idle cycle.
While reading some this evening it seems that there are different ignition coils for a SB versus a BB. SB = 1115270 while a BB uses 1115287.
Is there truly a difference between the two coils as far as construction?
Is the AC Delco U505 the correct coil for a 72 BB?
Any assistance or insight is greatly appreciated.
I should also mention that after reinstallation of the distributor, I did set timing and even set the dwell to the specifications listed on the firewall emissions decal.
It seems like it misses badly when starting to engage the clutch from a stop. If I have the rpms a little higher than I like or rev the engine just a little before I begin the clutch engagement, then everything seems fine.
I was originally thinking a carb issue but it seemed to happen immediately after the distributor rebuild and the coil replacement.
As for the coil specs, I didn't think there would be a difference. I read in some thread on the forum here that something like 80%percent of carb/fuel issues are ignition issues thus why I was thinking it was something silly I did in the distributor.
Maybe I'll just open the idle air mixtures screws a half a turn each to see if things improve some.
I do have the old coil. I tightened the center screw in the coil wire hole and that stopped the leaking oil.
I'll try the old coil first followed by the carb adjustment if things haven't improved.
As for the oil leaking, there is a screw inside the coil tower. I presume it holds the terminal in place and in contact with the internal connection. It was a little loose so I tightened the screw and no more oil.
I did put the old coil back on yesterday evening and the "Loading up" issue seems to be gone. I will drive it a bit more next week to confirm. Maybe the new coil was just a bad one.
One note on the new coil though, it was slightly larger in diameter. Not enough to present any mounting issues in the coil mounting bracket but large enough that it barely fit into the bracket with the clamp screw having only 2 or so threads in the bracket.
I had to open up the bracket ears a little bit and found that an electrical outlet/fan work box screw has the same thread pitch.
I used one of them which is a longer screw which gave me a few more threads out the other end and placed the heat reflectix product on the bottom of the coil as it sits almost on the intake. It's all hidden under the shielding anyway.
Nothing new is a direct fit it seems.
Marshal
