I have located a rust free replacement frame for my 71 small block car w 4 speed trans. Would there be a lot involved in making the big block C3 frame work??
so the replacement frame is from a similar year corvette , namely 68,69,70,71,72,?
the BB and the SB use exactly the same mounting points and bell housings ,so any early vette frame will accept a BB or SB.
If its a 73 or 74 the frame starts to get different as in regards to mounting the "new " bumper type
the only thing I would be concerned with is the measurements of the replacement frame , if its from those 5 first years , no one pulls apart these cars for no reason ,so its more than likely it was involved in an accident so it could be bent .
the only thing I would be concerned with is the measurements of the replacement frame , no one pulls apart these cars for no reason ,so its more than likely it was involved in an accident so it could be bent .
The replacement frame is from a 74 car and yes, I have already gathered up the frame dimensions for the very reason you stated. Indeed, why would a perfect frame exist separate from the rest of the goodies.
I have read , from someone on this board who knows more about the history around these cars than I ever will , that GM sold the 74 frame as a service replacement for the early C3 , Also I have had a 74 frame here (parts car) and the bare rear is not to far from the early frame , I think there's a tab that needs to be cut off. More than likely holes drilled but definitely do-able !
Just a thought , if your frame is rusted too badly ,how's the birdcage ?
A 74 frame is a modified 69-73 frame. And it can be easily un-modified. The four mounting holes for the front bumper will have to be re-drilled along with changing the two welded nuts on each side. The frame horns themselves are exactly the same as the 71. Check for cracks around the front spring pockets and lower a-arm mounts.
Mike
