Catalog exhausts
Old Oct 6, 2002 | 09:29 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Catalog exhausts
the true duals for the late sharks.. will they hook up to the stock manifolds? what do I need to hang em tool wise?
Old Oct 6, 2002 | 09:34 PM
79MakoL82's Avatar
79MakoL82
Default Re: Catalog exhausts (Markm10431)
Yours looks like it could be a 1982. Do you have two holes in the crossmember to accomodate a dual exhaust? I thought that the late late models had only one hole in the crossmember. The 1979 has two holes so it can accomodate the true duals. It hooks right up to the manifold. there's a dual exhaust hanger that attaches just before the tranny crossmember. On mine, there are two more hangers off the frame just before the Differential, and lastly the standard hangers at the rear of the mufflers.n Hope this helps.
Old Oct 15, 2002 | 01:18 AM
Markm10431's Avatar
Markm10431
Parrothead
Default Re: Catalog exhausts (79MakoL82)
actually, no hole. a bend in the crossmember under the passenger accomodates the front y pipe and the cat.. should be wide enough for a pair of 2-2 1/2" pipes
To Catalog exhausts
