I would like to know if the engine in my car (only 30000 miles) is the original engine. I read on here about two set of numbers. My engine has only one set of numbers with no letters. The numbers are as follows: 28371
Any help would be appreciated. Dennis
Is that number stamped onto the 3/4" X 3" pad right in front of the right cylinder head? If so it's way too short to be the serial number.
Yes to the placement of the numbers. That is the only numbers there. I thought someone would know what they meant. Warranty? Or replacement engine for any other reason.
Numbers do not match any number in VIN. No photo needed, there are no other numbers. This is not a big deal was just curious if anyone knew or had seen an engine numbered like this.
