Wilwood Caliper Front Pass D8-4 sucking air?
Car starting pulling a month ago. I had new upper/lower control arms and coilovers installed 2 weeks ago. So the suspension should not be a issue. Pads are at 75% or more. I can find no leaks and the shop found nothing while doing the control arm install. They also switched out the rotor so they were all over that wheel. Its really a crazy issue thay I can't find a simple solution for.
Then could also try moving the brake pads left to right. This is a simple process and requires no opening of the brake lines.
When you remove the pads also carefully inspect the pistons for any signs of contamination on the weak side.
Lift the front of the car and see if both front wheels spin with the same effort. Then apply the brakes and release and see if anything changes. Then could also try moving the brake pads left to right.
