Steering Rack Problem
Old Oct 5, 2017 | 04:16 AM
PBCloud's Avatar
PBCloud
Default Steering Rack Problem
1970 C3 454
I need to remove the tie rod end in the photo shown to replace the rubber boot/seal, however when I turn the castellated nut on the tie rod end as shown in the photo it does not release but just turns with its threaded section which does not have a nut on the other end to hold onto to stop it turning.
Any tips welcome.
Kind regards
Paul
Old Oct 5, 2017 | 05:58 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Try using an impact gun, also lots of times this works; try tightening to seat the tapered shaft then loosen nut. Tie rods ends that spin are usually worn out. T
Old Oct 5, 2017 | 06:56 AM
71VetteLover's Avatar
71VetteLover
Put a large c-clamp on the tie rod end to force it into the link (making it tighter) then blast the nut with an impact wrench.
Old Oct 5, 2017 | 12:46 PM
Drifter36's Avatar
Drifter36
Originally Posted by PBCloud
1970 C3 454
Any tips welcome.
Kind regards
Paul
Paul
It looks like there is a slot on the end of the thread for a big old screwdriver.
Old Oct 5, 2017 | 01:43 PM
High Country 72's Avatar
High Country 72
It maybe the photo or just my eyesight, but it look like the cotter pin is still installed in your photo. Make sure i's removed and then try tightening nut first to re-seat the taper then loosen it.
To Steering Rack Problem
