A weird LS C3 Swap (I need some help please)
Hey all, I just recently got an 01 2 wheel drive Silverado HD donor truck to use for my LS swap on my 78 Corvette. The truck has the 6.0 backed by a 4L80e. My car currently has a 700R4 and 383 stroker combo. The car was originally a 4 speed car, and has a fixed crossmember. My question about the trans is, is the 4L80e the same size as a 700R4? I've read that they are, but I don't know for sure. Also, where are those of you with LS motors getting your harness, and were you able to make it talk to your stock gauges? Finally, how can I modify my stock AC system to work with this motor? Thank you in advance for any help you may be able to give.
This thread i am making will soon have all the questions answered on a LSX swap.
https://www.corvetteforum.com/forums...post1594982249
But a 6l80e will fit so a 4l80e certainly will. You may be better off getting a 1980-82 cross member that is removable. Modifying the mounting plate and getting a adjustable trans mount.
As for AC the answers are in the link above
I have not got up to wiring harness yet but a few questions are answered in the link.
