'76 THM 350 Bolt Question
Old Oct 7, 2002 | 11:40 AM
1976corvettestingray's Avatar
7th Gear
Default '76 THM 350 Bolt Question
Can anyone tell me if all the bolts holding the transmission oil pan to the trans should be the same diameter/thread/length? What should they be? Any suggestion how I could find out?
Old Oct 7, 2002 | 01:52 PM
Schwee's Avatar
Schwee
Default Re: '76 THM 350 Bolt Question (1976corvettestingray)
They are the same thread and diameter, but the two holding on the little bracket for the cable (it's obvious when you look) are a quarter inch longer.
Old Oct 8, 2002 | 11:01 AM
7th Gear
Default Re: '76 THM 350 Bolt Question (Schwee)
Thanks Shwee,
Do you know the diameter and pitch of the bolts? Where did you get your information?
Scott
Old Oct 8, 2002 | 11:49 AM
page62's Avatar
page62
Help us out here...what's your situation? What did you find?
Old Oct 8, 2002 | 12:34 PM
7th Gear
Default Re: '76 THM 350 Bolt Question (page62)
I dropped the pan to replace the filter and one of the two bolts holding that shift cable bracket on was loose. It looked to me that it was undersized for the hole or a previous owner stripped out the threads. I am looking for accurate information on which bolts go where and thier size so I can determine what SHOULD be there and then decide if I need to retap, helicoil, etc. I have digital pics I can Email to you but there isn't much you can tell from them.
[Modified by 1976corvettestingray, 4:44 PM 10/8/2002]
Old Oct 8, 2002 | 12:42 PM
page62's Avatar
page62
All bolts are the same size and thread (1/4-20? -- not exactly sure). Only the length differs on the shift bracket bolts -- I saw this myself when my tranny was swapped out recently. So your helicoil should be the same size as any of the other bolts...
Sounds like Bubba did the previous tranny filter change :smash:
Old Oct 8, 2002 | 12:46 PM
7th Gear
Thanks, I'll add this to the project list. :eek:
To '76 THM 350 Bolt Question
