Centwer gauge ID
Old Oct 8, 2017 | 02:34 PM
michaelroy's Avatar
michaelroy
Default Centwer gauge ID
I currently have dash out of my 79. what is the little printed circuit board pictured here? (boittom left pic 1) it has a bulb on the other side. If this has nothing to do with the tach, which isn't even in the same location as the tach, then there was not a tach board in my speedo/tach gauges. picture 2.
There was nothing attached to speedo/tach cluster where the 3 connectors are located. (pic2)
How was the tach even working???????
Old Oct 8, 2017 | 03:00 PM
78pace's Avatar
78pace
Where is the low fuel light on a 79 is it in the dash? Could be for that.
Old Oct 8, 2017 | 09:13 PM
'75's Avatar
'75
That circuit board is for the low fuel light. Your tach plugs in from the front side and the studs protrude through the printed circuit in the 2nd pic.
Old Oct 9, 2017 | 07:39 AM
LenWoodruff's Avatar
LenWoodruff
On my 78 the low fuel light pc board is on the right side of the center console.
Old Oct 9, 2017 | 10:01 AM
78pace's Avatar
78pace
Mine is in the center console. At one point I was looking to replace it ...not working. But I found out then nobody makes them. Could be different now. But at that time Willcox could fix them I believe. Or he had a limited amount of used ones. I forget now......Stinks getting old.
Old Oct 9, 2017 | 01:00 PM
michaelroy's Avatar
michaelroy
Default Tach Board
I am reviving my post to answer one final question. I have discovered my car did NOT have the tach board attached to the back, as you see from the pic 2.
I was unsure how to remove the 3 contact points in order to install a new printed circuit board under them.
The tach worked (not sure of accuracy) apparently with out the board.
What is the purpose of board? I assume I need one???
Old Oct 9, 2017 | 01:02 PM
michaelroy's Avatar
michaelroy
Default Tach Board
Without this forum and especially the videos from Willcox I would be lost.
Old Oct 9, 2017 | 02:34 PM
78pace's Avatar
78pace
It is not a board per say...it is there. It is more of a thicker piece of plastic (that will flex)with the copper running thru it. But yours is there.
Old Oct 9, 2017 | 08:13 PM
'75's Avatar
'75
The tach board is attached to the rear of the tach and the studs extend front to rear through the contact clips shown in the pic. Those clips can be removed by pinching them together.
Old Oct 10, 2017 | 10:00 AM
michaelroy's Avatar
michaelroy
Thanks '75. I suppose I never had a tach board. Just one more part to purchase?
Old Oct 10, 2017 | 05:20 PM
'75's Avatar
'75
Your tach would not have worked without the board. Here is a repair procedure from Willcox that will explain where the board is located.
http://repairs.willcoxcorvette.com/w...allation-2.pdf
Old Oct 10, 2017 | 05:47 PM
LenWoodruff
Can you adjust the tach if the readings are off? Or do you have to replace it?
Old Oct 10, 2017 | 05:49 PM
'75's Avatar
'75
It depends who made the board, some replacements have an adjustment pot.
Old Oct 10, 2017 | 05:53 PM
LenWoodruff
Mine is factory original.
The rear I ask is that I have an 78 L82 with 3:55 gears and the tach shows 3500 RPMs at 70 MPH. The thread indicated that that would be the RPM's for 3:73 or my tach is registering wrong.
To Centwer gauge ID
