Rear Brake Rubbing Issue
Old Apr 22, 2018 | 09:42 PM
  #41
Peterbuilt's Avatar
Peterbuilt
If you are working on the passenger side (the right side) then it looks like the STAR adjuster is facing the wrong way.
See post 29.
Rubber or stainless brake line should not have a bulge.
With the tire off and no lug nuts to hold the rotor, it will wobble.
Old Apr 23, 2018 | 10:49 AM
  #42
C3InPA's Avatar
C3InPA
See post 29.
Thanks. I pulled the entire parking brake mechanism out, so there's nothing there now. Also, thanks for the clarification on the wobble. I guess the next step is to take the rotors apart again to see if I have a loose caliper bolt or something like that.
Old Nov 18, 2025 | 05:00 PM
  #43
76Murf's Avatar
76Murf
4th Gear
Hi, I just came across this thread and I'm wondering if you ever solved your rotational scraping issue. I have a 1976 Vette that has the same issue. Thanks!
Old Nov 19, 2025 | 03:02 AM
  #44
Haggisbash's Avatar
Haggisbash
I had a similar scraping noise and found one of the parking brake drums was out of round (the disc run out was fine). Machined the drum to true it and no more noise.
Old Nov 19, 2025 | 11:37 AM
  #45
76Murf's Avatar
76Murf
4th Gear
Thanks for the reply. I thought it may have something to do with the E brake and am going to try adjusting them today to see if it makes a difference.
