78 C3 heater blower speed?
Old Oct 9, 2017 | 04:24 PM
Douglas Brown's Avatar
Douglas Brown
Default 78 C3 heater blower speed?
My blower pushes good air but only at high speed dose not change when switch is moved, lo > hi or hi > lo, same speed. I checked the resistor cleaned contact where wires plug onto. I read where some felt there problems was the relay???
I know I thought at one point the blower should not run all the time. like when you switch to off, but I was told it is made to run all the time and it says that in the owners manual.
Anyway back to the speed control switch and check fuses. Tomorrow.
If there are any ideas I interested.
DB
Old Oct 9, 2017 | 04:58 PM
mikep3's Avatar
mikep3
http://repairs.willcoxcorvette.com/1...-blower-relay/
Wilcox is one of our supporting vendors that has diagrams showing just about everything corvette.
Old Oct 9, 2017 | 05:30 PM
Douglas Brown
Thanks Mikep3..I will apply what you have sent and see what happens.
DB
Old Oct 9, 2017 | 09:15 PM
Douglas Brown
Took the relay off and opened it up to check points, NEW. not surprising they are new.
configuration is a little different, the wire harness comes from Lectric limited. Relay from Cor. Am. should not make a difference. Orange Black
Purple
Red Dark blue
A/C BLO Res. Conn. is good and clean. also new.
All connections are attached to new harness from Lectric Limited.
In looking over the Willcox page/Diagram, The only item I do not remember hooking is an Idle stop switch ??? is this a required item to make it work????
Heater control blower switch is the speed control switch as shown in the diagram.
Will check fuse tomorrow.
DB
Old Oct 10, 2017 | 06:34 AM
mikep3's Avatar
mikep3
Take a look at this diagram on how the it should be wired.
Old Oct 10, 2017 | 11:05 AM
Douglas Brown
Thanks mikep3
Old Oct 10, 2017 | 11:20 AM
Douglas Brown
A little reading on the subject and I find the idle speed solenoid function is to maintain idle when at stop in traffic while A/C is on. ( I had not thought of this, will look into it)
So this function is not related to the A/C blower speed problem nor has a direct effect on the Blower speed switch, Relay, Resistor.
While assembling the carburetor / auto choke I needed ignition hot for choke to work I went to the A/C blower Resistor wires for this wire.
Last night thinking that may cause a direct link to my problem, today, I will find another wire connection for the choke.
Old Nov 4, 2017 | 05:10 PM
Douglas Brown
To close this out; Everything appears to be working fine... moving on to next area of concern.
Old Nov 6, 2017 | 06:35 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Dang it.. it's two L's.. lol..
I guess I'm going to have to start searching post for one to find them all...
Willcox
To 78 C3 heater blower speed?
