Since I lowered my C3, about 1.5* right hand and 1.7* negative left hand side. Would like to get it a little closer to 0* AND keep as much positive castor as possible. Car does corner very well now, and at speed (60 mph plus) I can turn the steering wheel about a 1/4 of an inch before I get a response. Any ideas? First photo is RH side.
You increase caster by removing a front shim and adding a rear shim to maintain ABOUT the same camber (it does change a little bit). What is your caster set to right now? I set mine to an even 2-1/2 degrees and my camber to ZERO (straight up and down).
It looks to me that by lowering the front end you have created a whole new problem. The lowering has increased negative camber so much that you have run out of adjustment. In your first photo of the right side of the car there are no shims left in the front bolt and enough to give you proper (or some) caster in the rear so you can't reduce the negative camber anymore without reducing caster dramatically. The left side has a bit more adjustment left but it looks to have been set to about equal or mimic the right side settings as there is no point going past what you can do on the right side. I believe that by lowering the front you have gone past an alignment or adjustment problem and it is now a geometric problem. Basically, you have run out of adjustment room.
Moog K6104 available at all your favorite parts suppliers. I used them on mine and slotted the bolt holes 1/4" and slid them to the rear for more caster too.
Why do you want more caster? Are you planning on running it at the Bonneville salt flats?
I suspected that was the case, I just needed confirmation of my suspicion. I've already ordered the Moog kit.
Hey '75, might you explain how you went about slotting them? I'm considering doing that also as long as I have to replace the shafts.
My first plan was to weld up the original holes and re-drill them 1/4" to the front, but the weld was harder than the shaft and the drill walked around to much. I bought another set of the moog shafts and just used a carbide burr on a die grinder to slot them, the shafts are somewhat soft and grind easily. A machine shop would have an easy time slotting the holes with a milling machine. There are old threads here where others have done it, but the pictures may be gone due to the Photobucket scam.
So why did you feel you needed more caster? Are you driving it in excess of 250 mph?
I lowered my car and put globalwest arms on it and had the same problem. Rather than do anything mentioned above I had my frame pulled out so I could get the alignment right. Before i lowered mine the top of the wheel well arm measured over 29" from the ground. My car had been wrecked before and going this route gave em the piece of mind knowing the frame is ok and the car now sits like it should have when new.
Slop is a product of slop!
Go with a Borgeson Joint and throw the Rag joint in the trash! Also don't know if the 12:1 Manual Steer Flaming River Steering boxes are still available and you might consider going to Heim/sphericals instead of the conventional tie rod ends to make it all tighter! Actually compared to other people's cars, 1/4 in of play isn't bad at all!
