78 power windows
Old Oct 10, 2017 | 04:45 PM
gz78's Avatar
gz78
Cruising
Default 78 power windows
I must have a break in one of the wires coming from my power window relay. If I wanted to run new wires from the relay, does anyone know the best way to run the pink, pink and black and orange and black wires? I think when I just got my car painted, the painter pulled the wires for the windows, and may have disconnected something from the fuse panel. I see the orange and black wire in the fuse panel, but do not see the pink and black or pink wire anywhere after it leave the relay.
Old Oct 10, 2017 | 05:08 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There should be two plugs into the fuse cavity...
Old Oct 10, 2017 | 05:17 PM
gz78's Avatar
gz78
Cruising
So do you think I can run a wire from pink and black wire from relay to ignition cavity in fuse panel?
Old Oct 10, 2017 | 06:21 PM
71VetteLover's Avatar
71VetteLover
I would think the painter simply forgot to plug the wires back into the power window motor.
Old Oct 10, 2017 | 06:38 PM
gz78's Avatar
gz78
Cruising
I replaced the motors. There is no power going to the wires for the windows.
Old Oct 11, 2017 | 11:58 AM
gz78's Avatar
gz78
Cruising
Update: I have power at the relay from the orange and black wire, but nothing at the pink wire or the pink and black wire. Suggestions?
Old Oct 11, 2017 | 03:23 PM
henrikse's Avatar
henrikse
Default power
Do you have a meter or test light? Start at source and ensure 10 amp fuse is good. Check it well as these fuse box contacts are famous for corrosion and even if the fuse looks good may not go thru the contacts. Measure voltage at both sides of fuse. If good follow pink/black wire to connector (20) and then to relay. Make sure your grounds for the circuit are good with your meter
Old Oct 14, 2017 | 11:36 AM
0Willcox Corvette
Former Vendor
It's very common for the contacts to corrode, I would also test the ignition cavity where the pink and black plugs in. If you don't have power on the pink and black you won't have power on the pink.
Many people test the fuse but forget to test the contacts. If there is corrosion the fuse can be good all day long and still not pass the current. So test the contact on the left of the fuse first.
Willcox
Old Oct 14, 2017 | 10:15 PM
gz78's Avatar
gz78
Cruising
Willcox
Thanks, got them going
To 78 power windows
