Torque Thrust D questions
Old Oct 7, 2002 | 04:55 PM
flood's Avatar
flood
Default Torque Thrust D questions
I really like the look of the torque thrust D's.
The problem is that they aren't listed for Vettes. I have heard that you have to use a spacer of some sort to get them to work :confused:
Does anyone have more info on this? Has anyone done it that can lend some info?
I have a stock setup and will be upgrading the suspension soon, I would like to put some better tires than can be found for the 15" stock rims.
Here is a link to the American racing website with the torque thrust D wheels. I suppose that a 16x8 is what I would be looking at. What kind of bolt size circle should I be looking for? Also what about back spacing and all that jazz?
They should just make them for Vettes, it would be easier.
http://www.americanracing.com/wheels...e=Torq-ThrustD :cheers:
Old Oct 7, 2002 | 05:19 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Torque Thrust D questions (flood)
I think that you need at least 1/4 inch spacers...
:cheers:
Olivier
Old Oct 7, 2002 | 07:05 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
http://forums.corvetteforum.com/zerothread?id=395116
Old Oct 7, 2002 | 07:07 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
If you like the Ds check the TT2s.. they are direct bolt on
Old Oct 7, 2002 | 07:23 PM
Brett K's Avatar
Brett K
Why not just go with these in 17 inch. They are being made in 2 piece so you can custom order with correct backspacing.....
http://www.vintagewheelworks.com/index.html
Old Oct 7, 2002 | 08:58 PM
flood's Avatar
flood
Default Re: Torque Thrust D questions (Brett K)
It seems as though alot of the rims is guesswork.
The stock rallies are 15 x 8 with 4" bs (0 offset) ?
So would a 16x8 with a 4.5" BS (.5 offset) work on a C3?
I might give em a call for prices on the 17" rims and see if they know what dimensions I need. I just really want to avoid getting rims that won't fit. Plus I have never bought rims for any car. So , I am a super rookie ! :cheers:
Old Oct 7, 2002 | 10:05 PM
ScubaJKD's Avatar
ScubaJKD
If you like the look of the torq thrust D check out the http://www.vintagewheelworks.com they make a TTD in 16" that will bolt on and only requires a 1/8 inch spacer or slight grinding on the calipers. I bought them and love the classic look with the new high performance rubber.
Old Oct 7, 2002 | 11:59 PM
trw's Avatar
trw
I just bought a set of 15x7's. Got them today. I figure they will work, at least for the fronts. I am going to take measurements and see if the 8.5's will clear the back.
Let you know in the next day or two.
Terry
Old Oct 8, 2002 | 09:25 AM
StingrayRacing's Avatar
StingrayRacing
American Racing makes a CL205 which is actually a TT2 with a grey center to make it look like the TTD....and its available in 15" - 20" sizes.
http://www.wheelsforless.com/american_racing.asp
http://www.wheelsforless.com/search_...oduct_ID=AR205
Old Oct 8, 2002 | 10:43 AM
flood's Avatar
flood
Default Re: Torque Thrust D questions (StingrayRacing)
The CL205 and Vintage Wheels look really nice, plus can be custom made to fit ! thats great. A little bit more expensive at 247.50 (15") Or $304.00 (17").
These things are pretty expensive. Plus Tires. Plus my suspension upgrade. Hope it all works out in the end.
All in all, alot better price than buying a new car. Alot better. :yesnod:
To Torque Thrust D questions
