'73 Horn Woes
Old Oct 13, 2017 | 10:44 AM
TERRY CLARK's Avatar
TERRY CLARK
Default '73 Horn Woes
My horn has never worked on my '73. Horn was bad, so I replaced it, still nothing...then took relay apart, it was fried, replaced it...now horn blows by touching the Steering Wheel. When I took the wheel off before replacing anything I found plastic pieces in the column...Anybody know what the plastic piece was and where it goes? thanx
Old Oct 13, 2017 | 11:01 AM
MelWff's Avatar
MelWff
there are a number of plastic components involved with the horn function in the steering wheel. Below is a link showing the possibilities such as the horn contact,contact spring kit, etc.
https://willcoxcorvette.com/catalogs...year=23&q=horn
Old Oct 13, 2017 | 12:00 PM
TERRY CLARK
Thanx...Looks like the Horn Contact Plastic Retainer maybe, Where in the Column does it go? Between the Large Spring and the Brass Contacts.
Old Oct 13, 2017 | 03:38 PM
henrikse's Avatar
henrikse
Horn won't work without it. attached column pic
Old Oct 13, 2017 | 03:46 PM
Aerovette's Avatar
Aerovette
Most likely. They get brittle with age. I glued mine a couple of times before ultimately replacing it. There is a hollow post that breaks and it is usually the source of the problem.
Old Oct 13, 2017 | 04:27 PM
TERRY CLARK
I don't see it or the large spring in this illustration.
Old Oct 13, 2017 | 04:28 PM
TERRY CLARK
I just ordered it....mine was in tiny pieces !
Old Oct 19, 2017 | 04:39 PM
TERRY CLARK
Horn works now......can give my finger a rest !
To '73 Horn Woes
