FrankenRat Buildup
Old Oct 7, 2002 | 04:57 PM
Lasse's Avatar
Lasse
Default FrankenRat Buildup
Has anyone read about the FrankenRat buildup in Chevy HP magazine? Does anyone of you have this 454 HO engine in the Corvette and if so, what do you think about it?
I have planned to buy the engine and in the first step add:
Edelbrock Performer RPM Air Gap intake
Aluminium GM valve covers
MSD 8572 distributor and my existing MSD6AL box.
Existing headers and Holley 850DP
To get a reliable engine with fuel economy and 'enough' HP/TRQ for streetdriving (450HP/519lb-ft).
Is it anything special to think about when I shall fit the engine with my existing option?:
Boltpattern bellhouse
Flywheel manual
Starter
Boltpattern for PS-pump and generator
etc...
Thanks!
[Modified by Lasse, 10:05 PM 10/7/2002]
Old Oct 8, 2002 | 12:03 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: FrankenRat Buildup (Lasse)
Sorry I can't help you with specific experience with that engine but it sounds like a nice combination that you have in mind. The bolt pattern for the bellhousing is the same as the older MK IV engines. I'm not sure about the flywheel.
Old Oct 8, 2002 | 02:47 PM
Corey_68's Avatar
Corey_68
Default Re: FrankenRat Buildup (burners)
I too have been following "Frankenrat", I'm anxious to see what power they get out of it. The install should be very straightforward. :cheers:
Old Oct 8, 2002 | 02:53 PM
Tominator's Avatar
Tominator
The cheap price of the engine is a good bargin, but then for a little more the 502 engine. So many choices :cheers:
Old Oct 8, 2002 | 03:07 PM
Fevre's Avatar
Fevre
What's wrong with your current set up? Sounds pretty ballsy to me. :yesnod: If nothing wrong with your current set up, get a set of alum heads and FI.
Old Oct 8, 2002 | 03:42 PM
Lasse's Avatar
Lasse
Yes, my 'existing' setup is good, but...
The engine has broke and I must do a rebuild of it. I must buy a new valve train: cam, hyd.roller lifters, pushrods, valve springs etc. and new pistons, damper .... and take the engine to a machine shop... :rolleyes:
When I saw this project, I thought that I got a brand new engine for nearly the same money, If I sell the parts from my existing one.
(~$6500 with shipping and Swedish taxes)
Of cource, I lose ~50HP, but I can forget the engine for a while (maybe...). I can drive longer distanses with a reliable and economic engine.
It's not easy to choose, but I think it's time to do it soon....
[Modified by Lasse, 8:43 PM 10/8/2002]
To FrankenRat Buildup
