Adjustable Rear Leaf Spring
Old Oct 17, 2017 | 10:54 AM
The Punisher's Avatar
The Punisher
Default Adjustable Rear Leaf Spring
Thought this looked intersting
http://www.ebay.com/itm/C3-Corvette-...lZwBKB&vxp=mtr
Old Oct 17, 2017 | 12:25 PM
Tonio's Avatar
Tonio
Not seeing the advantage over a simple nut and threaded bolt setup to do the same thing. And for over $400? The trailing arms need to be cut up too.
Old Oct 17, 2017 | 06:56 PM
bazza77's Avatar
bazza77
I have seen guys put springs over the original type bolt to counter the negative G they see on the way to the shops or while cruising along the beach front in summer .
Old Oct 19, 2017 | 12:54 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Rather than squishing bushings at various angles throughout the travel, this setup takes the hysteresis out of the equations and allows for smoother motion. I dont see the benefit unless you are racing the car.
To Adjustable Rear Leaf Spring
