76 Bouncing Tach
Old Oct 18, 2017 | 09:26 PM
elpasorabo's Avatar
elpasorabo
Default 76 Bouncing Tach
Hey folks recently did a little work around the engine on my 76 and now the tach bounces at all speeds. Any thoughts on the cause? It is not cable driven but electric.
Old Oct 19, 2017 | 09:20 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Check your connection at the tach filter... make sure it's no corroded. Your engine work may have disrupted something. Check the connector at the location A in the picture below. If this doesn't solve the issue, then remove the connector from the distributor and plug A into it directly and see what happens.
You can run the tach without the filter on a temporary basis.
