Ti ignition problems
Old Nov 4, 2017 | 06:39 PM
  #61
1969monzared's Avatar
1969monzared
Originally Posted by 69427
Yeah, a resistor in a circuit will appear "invisible" when the wire is open circuited.
If you can get a clean ignition supply to that white wire let us know what the voltages are in the circuit, particularly the voltage across the coil (C+ to C-).
Heading out to dinner right now, I'll check in later on. Good luck.
69427,
thank you for the help. I will work on it tomorrow morning and submit a reply by late morning
Old Nov 4, 2017 | 08:35 PM
  #62
1969monzared
Originally Posted by 1969monzared
69427,
69427,
one question, even it there is a resistance wire, I tried to jump the white wire off the horn relay, wouldn’t that be a consistent 12v?
Old Nov 4, 2017 | 10:45 PM
  #63
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
69427,
I don't have the wiring diagram immediately handy, but I just took a peek at my horn relay, and there's a couple rather large red wires attached to it, so I would assume there's a rather low impedance source feeding those wires. Once you've run a jumper to the relay, let us know what the voltages are at the different points in the circuit.
Old Nov 5, 2017 | 10:06 AM
  #64
1969monzared
So I think I verified that there is a resistance wire from the ignition module pink wire to the white wire of the TI ignition. Here are the comparisons:
Ignition pink wire readings with key on:
a) 8.9v @ white wire
b) + coil to ground 2.65v
c) + coil to - coil 2.4v
d) yellow wire 5.81v
Jumper wire from horn relay key on:
a) 12.4v @ white wire
b) + coil to ground 3.72v
c)+ coil to - coil 3.39v
d)Yellow wire 7.9v
Let me know what you think
Old Nov 5, 2017 | 02:19 PM
  #65
TimAT's Avatar
TimAT
I finally got home and a chance to look. The wire from the starter "R" terminal plugs into the pink wire at the distributor connector pigtail. NOT the coil as I had thought. (My bad. That's what you get going from memory)
Old Nov 5, 2017 | 03:42 PM
  #66
69427's Avatar
69427
d)Yellow wire 7.9v
a) Looks good.
b) Looks okay.
c) Looks good. That level of voltage across the coil calculates out to about 6-7 amps going through the primary windings. That's the number I believe that system is designed to operate at.
d) I'm not finding a yellow wire in the system drawing, so I'm not sure where that reading is at. Is it the wire immediately out of the module that feeds the coil C+ through the ballast wire?
Old Nov 5, 2017 | 04:33 PM
  #67
1969monzared
a) Looks good.
b) Looks okay.
The yellow wire is the wire that connects to the R terminal of the starter solenoid and to the ti harness (pink wire of the plug to the distributor)
Old Nov 5, 2017 | 06:15 PM
  #68
69427's Avatar
69427
Gotcha.
What's your next step?
Old Nov 5, 2017 | 06:43 PM
  #69
1969monzared
Gotcha.
After $6500 in ti parts, countless hours I guess back to points
Old Nov 5, 2017 | 07:02 PM
  #70
69427's Avatar
69427
Your car, and your decision certainly, but I'm a bit unclear about if there's additional issues that need addressing. The latest voltage readings appear to be correct. Will the engine start now if you crank it over?
(FWIW, the other drawing showing how to connect up an HEI module is the system I've been running the past 30 some years. The HEI is made to operate on the same signal that the TI distributor generates.)
Let us know if you continue, and try starting the engine.
Old Nov 5, 2017 | 07:18 PM
  #71
1969monzared
I’ve tried starting, cranks but no spark. Put a second amplifier with updated module in and still no spark. Would you mind giving me some info about your HEI module and I’ll look into buying one. Thanks for all your help.
Old Nov 5, 2017 | 07:22 PM
  #72
69427's Avatar
69427
Yeah. Gotta go take care of some stuff for a quick bit, but I'll get back to this thread shortly.
Edit: I'm back. Glad to help you out with any HEI info, but I hate to give up on the TI setup while the actual pinpoint problem is still unknown. It should be reasonably straightforward to do some simple tests of each segment of the TI system to see if we can identify which segment (supply voltage/wiring, pickup coil, module, ignition coil, distributor/rotor/cap, etc) is the problem.
Again, your call.
Old Nov 5, 2017 | 08:56 PM
  #73
1969monzared
Again, your call.
69427,
I would love to solve this. If you have some ideas I’m still game.
Old Nov 5, 2017 | 09:27 PM
  #74
Barry's70LT1's Avatar
Barry's70LT1
In post #14 I mentioned this, seems like a good time to mention again.
When I upgraded to the new TI amp board, I would get NO spark while cranking. I fixed this by...................................
Disconnecting the "R" wire from the starter to the TI harness. It makes no sense, however that fixed the problem.
Old Nov 5, 2017 | 09:31 PM
  #75
Barry's70LT1
What information do you need in addition to post # 37 ?
Old Nov 5, 2017 | 09:49 PM
  #76
1969monzared
Barry,
I was just thinking about that post. I’m to that point. I’ll give it a try. Do you know why it corrected the problem?
Old Nov 5, 2017 | 09:52 PM
  #77
1969monzared
Is it a module mounted in the engine compartment that allows use of the TI distributor or is it a HEI module retrofit into the distributor? Sorry, don’t have much experience with HEI
To Ti ignition problems
Old Nov 5, 2017 | 10:02 PM
  #78
Barry's70LT1
Barry,
I do not have a clue as to why that fixed the problem, it makes no sense, however it worked.
Old Nov 5, 2017 | 10:08 PM
  #79
1969monzared
Darn, tried it and no spark. Ugh
Old Nov 5, 2017 | 10:13 PM
  #80
69427's Avatar
69427
In my car I have a simple (but genuine DELCO) HEI four terminal module on a small heat sink attached inside the ignition shield by a small machine screw, using one of the already available holes in the shielding. I'm also using the stock 48 year old points coil (sans ballast resistance) attached to the HEI module. The points are long gone, replaced by an aftermarket variable reluctance pickup coil in the distributor. The system has been stone reliable/ bulletproof for several decades.
