The Green Mamba and your car are coupes. The body in the video shows how little rigidity the body adds on the C3. Imagine how little the body helps with a convertible like I have.
I'm doing what I can to stiffen it up.
Mike
You have a real challenge. Buddy of mine put in a full roll cage after his rear frame kickup structure failed. His is a 68 and I note the Green Mamba is of that vintage. I didn't watch the whole video but looking quickly I didn't see the bare frame so I can't tell if he added the frame gussets at the rear. That would help.
Well....that explains why Corvettes allow for the wide door gaps! No wonder the passenger door pillar on my basket case convertible has a vertical 12" crack. May as well beef up the frame before I "re-gap" the doors since I already replace all the body and frame mounts which corrected the sticking-closed door problems.
I would definitely check the welds back there. I imagine torque acting on that member would flex the body at the #4 mount. Obviously that is just a guess. Have a look at the difference between the 68 and 69 and up structure.
I welded the frame solid and did a lot of gusseting. I don't really want a roll cage, it is a street car. We'll see how it does when I finally get it on the street.
That's obviously a very high end no expense spared build by some very competent builders. I'm surprised there weren't some "custom" enhancements to address the possibilities of frame flex with all the horsepower and grip the car is capable of. Maybe the resulting performance exceeded expectations.
Not to say this is the case with this car, because I have no idea, but I have seen very high dollar builds in both cars and motorcycles that skipped the basics. I consider welding and gusseting the frame a basic with high horsepower, high end suspension and big sticky tires. If I had the budget that went into this car, I would have looked at a stiffer aftermarket frame or at least filling the stock frame with structural foam after it was welded and gusseted. Of course I would have put a cage in the car for it's intended use.
