Alu intake under SB hood
Old Oct 30, 2017 | 04:12 PM
Lord Melbury's Avatar
Lord Melbury
Default Alu intake under SB hood
I have just bought a C3 -69 L46 and I'm planning for the upgrades. Does anyone know if there is a performance alu intake with the same height as stock iron intake? It looks like the aftermarket intakes brings problem with hood clearance.
Håkan
Old Oct 30, 2017 | 04:23 PM
mobird's Avatar
mobird
Håkan
The old stand by is the Edelbrock Performer 2101
Old Oct 30, 2017 | 11:59 PM
Kid Vette's Avatar
Kid Vette
Or Weiand Action+Plus Intake Manifold 8004
Old Oct 31, 2017 | 03:32 PM
kansas123's Avatar
kansas123
If one replaces their stock intake with one of these 'performers', what exactly does that do for you, assuming you change nothing else. Just curious, always looking for a quick enhancer. Thanks
Old Oct 31, 2017 | 05:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
A little bit better flow, but mostly putting the front end on a diet.
Old Oct 31, 2017 | 05:15 PM
JoeMinnesota's Avatar
JoeMinnesota
Default Weiand Street Warrior
I am running a Weiand Street Warrior on my 1970 L46 after rebuilding with a roller and aluminum heads. I've been an Edelbrock guy for life pretty much, but chose this one as it performed slightly better than the Performer on a Hot Rod comparison of 23 different dual plane intakes, and had the shortest carb height out of all the manifolds. I am running the original (rebuilt and tuned) Quadrajet and original air cleaner, along with 1/2" of spacers under the car, still fits nicely under my hood. This is also an idle-5500rpm intake, same as the Performer, and the motor is definitely done before 6000 RPM with the Howards roller, also designed for 1600-5400rpm.
I've been really happy with my set-up and will be going to a deeper gear over the winter to snap it up even more.
Old Oct 31, 2017 | 05:19 PM
HeadsU.P.'s Avatar
HeadsU.P.
Håkan
Well yes and no on the aftermarkets. Take Edelbrock for example. They claim several of their intakes will not fit under Corvette hood. Will it? Yes. But because they don't want customers returning their products and worse yet, bad-mouthing their products they have to cover their azz. What their web site fails to tell you is that by using a Drop-Base Air Cleaner you can gain the neccessary clearance. There are fellas running the mid-rise Edel 7501 Air Gaps. But again, you have to have a drop-base.
Another option is to use a 2.5" > 2.7" air filter, thereby gaining a half inch or so.
I found two: NAPA 14" dia, 2 + 5/8 tall #6037
Fram 14" dia, 2 + 5/8 tall #CA3648
Someone has a 2 + 1/2" tall
Several have a 2" filter.
Old Oct 31, 2017 | 05:33 PM
Lord Melbury
I will also change to headers, probably Flowtech, they will fit without modification with a Borgeson steering box, as far as I understand.
Old Oct 31, 2017 | 05:46 PM
Lord Melbury
Thanks for your comments, my intake/header mods is not primarily to gain power, it's about look and feeling
Old Oct 31, 2017 | 07:46 PM
jb78L-82's Avatar
jb78L-82
The Aluminum L-82 intake is the same as the Edlebrock Performer and can be sourced cheap...there are lots of used ones that can be cleaned up easily and save you lots of money over the edlelbrock performer. Intakes alone will do very little for your motor if the engine is stock or lightly modified and you intend to keep the revs below 6,000 RPM. The best gain you can hope for is 5- 7 hp over the stock manifold on stockish type engines which you will not even notice.
My L-82 355 with AFR 180 64CC heads, Howard's roller cam (.525/.525 lift, duration 219/225,LSA 110 operating range 1,500-5,600 RPM) and 10.2:1 compression pulls hard to 6,000 RPM with big mid range range torque from 3,000-6,000 RPM. I also have Long Tube Headers of 1 3/4 inches into 2.5 inch duals. I rarely rev the motor beyond 5,600 RPM which is the reason I kept the OEM L-82 aluminum intake and was advised the same by the expert engine builder who did the bottom end of the motor. His comment was with my cam and the 180 AFR's, there was no reason to look at other intakes considering I was looking for great mid range torque with strong HP below 6,000 RPM.
Old Oct 31, 2017 | 08:03 PM
BLUE1972's Avatar
BLUE1972
I went with the Weiand on my 71 and love it. Great power and torque which I need on the street.
Old Oct 31, 2017 | 08:46 PM
Duntov's Avatar
Duntov
We ran an original LT-1 intake and factory air cleaner with no issues on a 70 L46.
Old Nov 1, 2017 | 12:22 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
this is stock original steel intake, painted.
If I did not tell you, you could not tell the difference, from Aluminum.
Old Nov 1, 2017 | 03:38 PM
SI67's Avatar
SI67
Cast iron, actually.
That's exactly what I suggested to someone in the C2 Forum who was interested primarily in the look of an aluminum manifold!
Old Nov 1, 2017 | 03:47 PM
TCracingCA's Avatar
TCracingCA
Some of us have part numbers memorized and could tell at a glance. This guy has a lot of choices that will fit, but the L-82 should be out there for cheap. I hate to advertise for the crooks at Edlebrock, so Weiand is a good Company. There dual plane Sleuths are pretty trick, but I don't know the height on them.
Old Nov 1, 2017 | 04:31 PM
7t9l82's Avatar
7t9l82
The L-82 intake and the performer are not the same. Set them next to each other and the difference is obvious. There is a little difference performance wise untill you make other changes then the performer picks up a bit more. Look in the plenum of either of them. A blind man can see the difference.
Old Nov 1, 2017 | 06:25 PM
jb78L-82's Avatar
jb78L-82
Either way, I would not use an Edelbrock 2101 over an aluminum GM L-82 intake....there is no performance difference....The Edlebrock RPM is different and offers maybe a 5-7 HP gain over the L-82 intake
To Alu intake under SB hood
Old Nov 1, 2017 | 07:04 PM
7t9l82's Avatar
7t9l82
I think with better heads like you have and hedders you would find more power than that. An RPM air gap would give you even.more.
Not trying to argue the point. But saying the two are the same is factually inaccurate.
Old Nov 1, 2017 | 07:12 PM
jb78L-82's Avatar
jb78L-82
You need to read this:
https://www.corvetteforum.com/forums...performer.html
and this for people who switched to an Edelbrock performer 2101:
Some say yes others say no difference. For the time, effort, and money, I would NOT choose the 2101 over the L-82 PLUS my builder who knows more about this than you or I said NOT to bother with a sub 6,000 RPM motor like mine. I went with the expert and could not be happier with the power of my motor....
Old Nov 2, 2017 | 01:30 AM
Bikespace's Avatar
Bikespace
The ZZ4 (or ZZ6) takeoff might worth looking at. Available on eBay, it is one of the few with provisions for EGR and choke heater tubes. Plus it has the firing order and a Chevy bowtie on it, so it looks as close to stock as anything else you are likely to find.
