What Headers fit a Big Block?
Old Oct 8, 2002 | 04:53 PM
69L71's Avatar
69L71
Default What Headers fit a Big Block?
I had a set of Hooker Super Comps but I sold them because they required a pretty big dimple to clear the Vette Brakes idler arm knuckle. I have a set of cast iron manifolds but want to survey the troops first to see if any of you have had luck fitting headers first. I'm tempted to try a set of hedmans for fit and if they work send them off to HPC.
Thoughts?
Old Oct 8, 2002 | 05:11 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: What Headers fit a Big Block? (69L71)
ive heard most of the onces made for C3s fit pretty well. Sidepipes should fit fine :D
Old Oct 8, 2002 | 05:27 PM
70BBvert's Avatar
70BBvert
Was wondering that myself - Ive seen a few with Hooker supercomps at some local shows. Thought they needed to be dimpled in a spot or two to fit though. I'm on the fence between stock & headers although I have a ways to go before I need to decide. Let me know if you decide to sell the stock manifolds.
Jim
Old Oct 8, 2002 | 05:36 PM
redvetracr's Avatar
redvetracr
I would of switched to a HD/stock or Moog HD Idler arm!!
...redvetracr
Old Oct 8, 2002 | 09:53 PM
73 LS-4's Avatar
73 LS-4
I think the dimpling depends on the primary tube size, My 1 7/8 required no modification to fit.
:cheers:
Pat Kunz
To What Headers fit a Big Block?
