BTO 200R4 - Power pedal is too hard
Hi,
I take the time to mount my new motor and transmission on my corvette (i have them since some years...).
I have a problem, in normal time (with spring on carb) i can't accelerate enough to open the secondary. The pedal is really hard inthe final course.
If i delete the TV cable or SPRING, it's easier to rich the maximum pedal course.
Does i have my TV cable too short? Power cable too long? With TV cable, does i need to keep spring?
A video will explain more :
Hi, if your cable adjustment was wrong you couldn't move the accelerator to the wide open position with the springs disconnected. You could try different springs?
I use these and I also have the 2004R transmission.
I think already see theses springs. Have you a picture of them mounted? Ideally the specific name to buy them...
if you have a 200r4 you can help me on the fine tuning...
in first could you tell me if when you use one of turn signal you heard the trans relay ? The same sound when you push the brake pedal... I think my turn signal ground is same as stop light...
thanks for all
thanks for all
thanks for all
thanks for all
I'm running my first road test. And after some km. The car stop because I think she don't go down. I finally restart but use it as a manual gear to go back at home.
the pressure test on the gearbox seems to be correct.
I already contact BTO to have more information, but even if i send some mail, for the moment i haven't any reply...
When converter is disengaged, the gearbox go down?
how I can check it?
how I can check it?
how I can check it?
how I can check it?
Hi, are you saying that the torque converter locked up and wont release when you slow down? Tell me more? What happens when you move off from a standing start, does the transmission up-shift normally and when it is in 4th gear does the torque converter lock up? Then you slow down and the engine stalls? Do you have a manual override switch on the torque converter solenoid circuit so you can force it to release?
I think that the lockup won't release.
the car upshift really fast.
I didn't have a manual override switch on lockup.
Received 2,127 Likes
No thank you, mine is working just fine and not interested in sanctions either. The TV valve has a stiff spring in the trans and acts against the throttle lever via the tv cable, my set up is not dangerous and no need for me to buy more springs. Run all the springs you want, I'm good!
Note,this circuit also includes a vacuum switch to automatically disengage lock up when the inlet manifold vacuum drops to a certain level when say climbing a hill or accelerating heavily, it is my understanding this is to protect the lock up clutch as this was never designed to take the full power of the engine.
In regards to the transmission upshifting quickly, at what RPM and throttle opening is this happening?
