LS1 Build Guide
Old Aug 12, 2018 | 09:04 AM
R6n350GT's Avatar
R6n350GT
Pistons, Rods, Cam, Crank all in !
Old Aug 12, 2018 | 05:32 PM
R6n350GT's Avatar
R6n350GT
Remember to add the cam retainer plate. Use blue loctite on thread and under the head.
Top two bolts are longer than the third bottom bolt.
Apply a little running in oil to the seal of the plate.
I used a LS2 chain which is single row but heavy duty and thicker than LS1 oem.
Install cam gear, blue loctite on bolts and under head of bolt.
Rotate crank so dot is at 12 o'clock position. Then make sure the cam gear dot is at 6pm so they are facing each other.
This is done before bolts are put in.
Check endplay of the cam by pushing the cam gear towards then engine and set dial indicator at 0.
Then push the cam from backside of engine and see how much end play there is.
Mine is 5.5 thou.
Next step is installing oil pickup tube and oil pump.
I am waiting for my oil pickup tube to arrive before i go further.
I will pack the pump with vaseline before installing.
Meanwhile im making a front case installer tool with a $2.50 aud part and a empty stick tape roll... Updates to come
Old Aug 15, 2018 | 08:15 PM
R6n350GT's Avatar
R6n350GT
Next step is oil pump.
Mount it on crank with blue loctite on the bolts and heads and line up the bolt holes and do hand tight.
Remove the front pump cover.
Use engine assembly tube or Vaseline to pack the gears, oil pickup area. It will help keep the gears in place and make pump easier to reinstall.
Re-install the pump cover bolts (9 ft lb)
Now turn over the engine a few times to centre the oil pump
Tighten the oil pump bolts a little tighter and turn over the engine some more.
Finally torque the pump bolts to 18ft lb
Also install the windage tray with all nuts (using running in oil on them) bar the one the oil pickup tube sits on. Do them up hand tight.
Now oil the o-ring, insert the oil pickup tube straight on.
Add the oil pickup tube nut on the windage tray.
Install the oil pickup girdle while adding blue loctite on the bolts.
Torque the oil pickup pump bolts before the windage tray nuts.
The girdle i used above was off ebay. They sent the wrong size bolts and the holes are too big for the right ones. It should not matter when using loctite.
I found this one later on from lsx innovations that uses much better design and quality. It was pretty much the same price. I recommend getting this one instead. I have used alot of their products and they have great customer service.
Before you install the oilpan if your oilpan does not have a provision for oil tube then you need to punch the block dipstick tube hole out.
Next step is to install the oil pan and gasket.
Here is what it looks like inside
Do the pan bolts up hand tight. You need to make sure the oil pan gasket holes will line up for the front and rear covers.
I would recommend testing the front and rear cover before you put the seals on and checking the bolt holes line up with the oil pan gasket.
I had issues with the rear cover..
Once you know the oil pan gasket is lined up and the pan is flush with the block then add some RTV to the corners and torque down the pan.
Front timing cover
This is the 40mmx32mm $4 part with sticky tape roll. it was PERFECT for aligning the case. Your welcome, just saved you guys $100 on case aligning tools...
Install the tool on the crank
Remember the gasket ! Add some RTV on the corners
I had to redo this due to gasket not aligning thus the recommendation above.. But once you know its lined up you can slide the cover on with RTV (the oil pan will be torqued down) so it will sit flush with the block.
Use running in oil on the bolts and heads then torque up.
Side shot of the engine and pan.
Rear timing cover
You should have already test fitted the rear case and made sure oil gasket lines up.
Now make sure the rear cover gasket lines up correctly.
Make sure the seal goes in with the "this side faces up".
Then use the old seal ontop to tap in the seal until its virtually flush with the rear of the cover.
This is how much you get in hand tight before you need to tap it in the rest of the way.
Add RTV to the bottom corners and hand tighten the bolts (apply running in oil to bolt and head) until the cover sits flat agianst the block.
Then you can check the 2 long oil pan bolts line up through the gasket and into the cover.
Once you get the 2 long bolts into the cover you can then torque the rear cover and then finish off the oil pan bolts.
Old Aug 15, 2018 | 08:40 PM
R6n350GT's Avatar
R6n350GT
Quick side track.
Rebuilding and cleaning LS1 injectors
First i made this but you can buy them off ebay
I covered each section of tubing with heat shrink.
Then used carby cleaner and applied 12v power and sprayed each jet until the stream was even
I brought a new seal kit.
To get the old filters out use a screw large enough so it grips the edges of the copper ring seat and then use pliers to pull out the old filters.
Then use a copper hammer tool to seat the new filters in.
Or some pliers with thin bit of metal over the filter and press it in.
Old Sep 2, 2018 | 04:55 AM
R6n350GT's Avatar
R6n350GT
Now time for the Heads.
They have been cleaned, 25 thou taken off, valve job done.
PAC 1219x springs
My Heads are the later 2004 which require the valve stem seals with the seats built in (.313" X 500" METAL CLAD GM TOP HAT)
After market COMP CAMS 774-16 valve stem retainers are needed.
I wish i was told these were needed when i brought my cam... caused huge delays but anyway..
First step was to install the LS7 lifters. They have been soaking in running in oil overnight. Need to do it for at least 20mins to an hour i have read. There are little drain holes in the lifters. It doesnt matter which direction you put them in. Blue loctite on the lifter tray bolts and oil under the head of the bolt.
They look so nice after being cleaned.
Always use new Headbolts. They come with thread locker already (similar to blue loctite). Just need to add some running in oil under the head of the bolt, or ARP stuff.
New headgasket. No need to use any other sealants. Just make sure they are on the right direction.
Look too good to be hidden !!!
Need a torque degree gauge.
Looks so nice all painted together. The LSX Innovation brackets and Energy suspension look awesome
Now to check push rod length. You need the firing order, cylinder number and to know if you are at top dead center on the compression stroke. You can tell by looking at the cam. See the lifter is on the low side of the lobe
Here is what the cam looks like if it where outside the engine. The X is where the lifter sits. Its the lowest point. If you are not sure then find TDC and push the pushrod into the lifter and down as much as possible. Keep turning over the engine until that piston is at TDC again. Which ever TDC allowed the lifter to be pushed in further is the one your looking for.
Then you can use these instructions to find what size you need.
https://www.ls1.com/forums/f7/how-me...length-172530/
Mine ended up being 7.375" using 241 heads with 25 thou taken off, stock MLS head gaskets, and a cam from ws6 store 218/227 .600/.600 112+2 LSA
