Clutch
Old Oct 8, 2002 | 10:35 PM
MarkJ's Avatar
MarkJ
Cruising
Default Clutch
Any big pointers on taking the trany out and putting in a new clutch.
Mark
Old Oct 8, 2002 | 11:43 PM
fauxrs's Avatar
fauxrs
Default Re: Clutch (MarkJ)
try my website, I put together a page on the beginning of my clutch job. http://earchitect.50megs.com/corvette/In%20A%20bind.htm
Old Oct 9, 2002 | 11:09 AM
fireball's Avatar
fireball
Jack and block the car up as high as you can... will make getting the tranny and bellhousing out much easier.
Old Oct 9, 2002 | 11:12 AM
lbell101's Avatar
lbell101
http://forums.corvetteforum.com/zero...020691#4020691
Old Oct 9, 2002 | 12:35 PM
Marks69BB's Avatar
Marks69BB
Default Re: Clutch (lbell101)
Not hard, just time consuming. As stated above, get the car as high as possible. You'll have to drop the exhaust, driveshaft, and remove the shifter to get enough room to rotate and pull the tranny back to get it out. Also, you may want to change the rear main seal, driveshaft u-joints, and rear seal in the tranny while you've got everything apart. I just got done doing this. :D Good Luck! :cheers:
To Clutch
