Block matching number mystery
Chevy engine blocks all had casting numbers from the foundry,
The other numbers indicate casting date and shift.
Casting month A = Jan, L = December, the heads also have part numbers as well as casting dates.
Almost all items on the car have "part / casting" numbers and date codes.
The NCRS books, restoration guides can give you the numbers.
Casting date looks like Sept 16, 68. = I 16 8
The block was cast on September 16, 1968 (I 16 8)
The block was used for 1969 model year 350 ci 350 hp engine (3922386)
The engine was built in Flint (V)
The engine was built in early October 1968 (1007)
The engine was built for a 1969, 350 hp engine, 4 speed, with air conditioning (HX)
The engine was installed in the car during October of 1968 (00582)
The car was built in late October of 1968
The numbers on the pad look factory correct.
The mystery is the pad surface under the serial numbers
It is known that the factory would grind out and restamp pads
What a great education
Thanks everyone.
Glenn in San Diego
I think you would enjoy getting the 68/69
NCRS manual for your year
http://cdn.zip-corvette.com/media/ca...-/b-704_13.jpg
and
also
https://prodimage.images-bn.com/pima...4_s550x406.jpg
I learned a lot from these books and even more on this forum, Thanks!
The NCRS guide is a big help as are MOST restoration guides.
As an example the PONTIAC historic society just admitted that a number of early 68 Firebirds had an engine vin that was off by one number due to a defective engine making it to the assembly line and not getting installed.
My friends father worked at a few assembly lines for GM and said they were cars - if you ran out you took parts from other lines and finished the days production run... funny when you think about todays processes.
I is skipped on many casting dates. looks too similar to 1
