Wipers/motor issue on 72
Old Nov 18, 2017 | 09:58 AM
72ragtop's Avatar
72ragtop
Default Wipers/motor issue on 72
I had the wiper motor restored about 2 yrs ago. Everything worked fine til I went to start one day. When the car started after sitting a few months. The wiper door opened and wipers started working til i shut the car off. Checked the switch. Was in off position. Both speeds worked. But motor continues to run as car runs. Checked switch, wiring. All good. In looking this issue up I've seen that the motor may not be going back into park position. Just wanted to see if anyone had ideas before i start pulling w/m out again. Thanks in advance
Old Nov 18, 2017 | 11:03 AM
NeverTooOld's Avatar
NeverTooOld
The problem is your switch isn't breaking contact. The switch provides the ground for the motor to operate and when you turn the switch OFF it's supposed to break contact. But it isn't breaking contact.
Old Nov 18, 2017 | 11:58 AM
D_Williams's Avatar
D_Williams
There could also be a short in the wiring somewhere.
In the off position, the switch should only ground the black/white wire which would then only ground the green wire at the wiper motor.
In low speed, the switch grounds both the black/white and the dark blue wires, which then ground both the green and dark blue wires at the motor.
In high speed, the switch only grounds the dark blue wire which then only grounds the dark blue wire at the motor.
Somehow, the dark blue wire at the switch always has ground. Whether it is the switch itself or a short can be determined by testing the wiper switch with the process in this video.
Good luck
Old Nov 18, 2017 | 01:45 PM
72ragtop's Avatar
72ragtop
Actually was the switch. when i took it off something was rattling inside. Put one on i had lying around and all works as intended. When i have time ill pry back the prongs on the old one and see whats rattling. Thanks to all.
Old Nov 18, 2017 | 02:10 PM
NeverTooOld
My latest Chinese made switch will shut my wipers off about 50% of the time. If the slide handle would move about 1/32" more to the left it would shut them off all the time. One of these days I'll take it apart and see if there's something I can do to it so it'll break the motor's ground 100% of the time.
Old Nov 18, 2017 | 02:56 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The china made switchers are junk.. we actually pulled them from the site. We carry a new switch that is LL brand. I don't know where it's made, don't care either... it works!!! The China switches have too many variables that are not correct.
CA actually contacted me because for a while I was fixing them and they wanted to know how.. But my success rate was about 25 percent and it's no fun taking the new switches apart and then only have a 25 percent fix ratio... It just wasn't worth the time.... So we switched vendors to one that works just fine.
Willcox
Old Nov 18, 2017 | 02:57 PM
0Willcox Corvette
Former Vendor
Good luck
LOL.. You beat me to my own stuff...
Old Nov 18, 2017 | 06:53 PM
72ragtop's Avatar
72ragtop
Thanks Never too Old. I was fortunate to have a few original lying around. Like those easy fixes.
Old Nov 21, 2017 | 09:13 AM
maj75's Avatar
maj75
Is it possible to repair the original switch? What causes their failure? I have an issue where the wiper functions seem coordinated, but the switch does not turn the wipers off. I have to turn the car off to stop the wipers. If it’s the switch, I’m hoping I can repair the contacts instead of buying a potentially more unreliable switch.
Old Nov 21, 2017 | 09:26 AM
0Willcox Corvette
Former Vendor
Yes, original switches can be repaired. You just have to be careful not to break the housing.
There are three tangs that have to be pried open, then remove the parts clean them insert a bit if dielectric grease and re-install. When you re-crimp the switch is the tricky part.
Willcox
Old Nov 21, 2017 | 09:28 AM
0Willcox Corvette
Former Vendor
I don't think the switch is the issue though...
Here are the main articles and videos on the web site to help you.
Upload and save this PDF first...
http://repairs.willcoxcorvette.com/w...-with-test.pdf
Video on testing the motor:
1969-1972
Video on testing the switch
Wiper Motor Bench Test 69-72
1969-1976 Corvette Wiper Motor Bench Testing and Some Relay Repair Help
Ohhhhhh sooooo Free Simple schematic.
Willcox-
18243
Old Nov 21, 2017 | 05:59 PM
ajrothm's Avatar
ajrothm
Willcox
I just installed one of your LL switches yesterday and.....it only works about half of the time. It does not detent well from OFF to LOW...goes straight to HIGH...and then sometimes when going back to OFF, the wipers keep running.
I put my original DR switch back in and it doesn't do any of this stuff.
FYI....
To Wipers/motor issue on 72
