Hey guys. I just acquired another Corvette, a 1976 L-82. Matching numbers car that runs and drives great. No unusual noises, no smoke, no blow-by and holds good oil pressure. However, it has a fairly noticeable vibration. It seems to intensify as the RPMs increase. It does it sitting still idling or cruising down the road. Same vibration with clutch in or out.
It has new motor mounts. new transmission mounts and a new clutch, (all done by the previous owner...probably chasing down the same vibration).
Any ideas what could cause a vibration like I described?
Check and record compression, look for a low cylinder, pull spark pug cable one at the time and see any impact on vibration/change.
The car doesn't have a miss-fire. It runs great...other than the vibration. It's firing well on all cylinders with perfect compression on all cylinders...each within 5lbs of each other.
I have one with a vibration issue in the 3k range. I've replaced the usual suspects and, I gave up. Hoping it will break and I can fix it. I really think it's in the back somewhere.
When I pulled the engine out of my 77 after I made the decision to rebuild it,I found the rubber in the vibration damper was dry rotted . Might want to check the one you have that could be causing you're vibration.
Just curious. Does the harmonic balancer appear to be spinning true? Or is there a slight wobble? Some of those old units tend to seperate, meaning the outer shell slips from the inner. Replacement isn't that bad a job:
Loosen A/C, P.S. and Alt so as to remove belts. But first, take a piece of masking tape and label each belt in order of removal and intial it for future location. Next using a boxend wrench remove fan, clutch, pulley. Now you have access to remove vibration damper bolt with torque wrench, slowly. You DO NOT want that to snap off! Now you can use a puller. In some cases the fan shroud will have to come out, not an easy task, but do-able.
Ahh. It will be wise for me refresh my memory from the first post.
Ok, so the drivetrain is out.
How about that clutch that was installed by the former owner? Can you get a good visual on that? No. Only thing I can think of is a flywheel that was not installed correctly or maybe warped? I assume a locator pin was on the end of the crank to align the flywheel correctly? Maybe a flywheel bolt came loose? Maybe a clutch bolt came off? Did someone use LocTite on the bolts? IDK. You can't see anything going on with those one piece bellhousings.
How about that clutch that was installed by the former owner? Can you get a good visual on those? No. Only thing I can think of is a flywheel that was not installed correctly or maybe warped? I assume a locator pin was on the end of the crank to align the flywheel correctly? Maybe a flywheel bolt came loose? Maybe a clutch bolt came off? Did someone use LocTite on the bolts? IDK. You can't see anything going on with those one piece bellhousings.
i don’t know much about the prior repairs, other than what the previous owner told me and the receipts from the Vette specialty shop that did the work. Of course, anyone could have done poor work or a part could have failed.
I recently helped a friend chase down a vibration in his 396
He mentioned the balancer, so I said to him well you've changed your belts in those 50,000 miles in your 50 year old car right? So why would you think the rubber in the balancer was not in need of checking?
We sent the Harmonic balancer to "The Damper Doctor" He reconditioned it and turned out real nice. But that did not fix it.
In any event, It turned out when the flywheel was cut the machine shop rookie cut it warped. Ended up resufacing it again. Well long story short he ended up with a brand new flywheel and now smooth as can be.
I would check the #5 and #7 spark plug wires to see if the previous owner crossed them. If they did get crossed the #5 cylinder would fire 90 degrees too late and the #7 cylinder would fire 90 degrees too early. And that WOULD cause a noticeable vibration at idle as well as at higher rpm's.
