Headlight switch question
Old Nov 25, 2017 | 02:46 PM
C376FL's Avatar
C376FL
Default Headlight switch question
Now if you go by the 76 AIM it shows the switch where the wires plug in from the top and the vacuum hose plug in on the bottom, which is correct to fit in the ground strap with the grove on top on one page, you look on another page and they show the plug coming in to the bottom and the vacuum hose on top. My ground strap has the grove on the bottom, so when I put mine back together I will have the hoses on top and the wires coming into the bottom. I guess what I am asking is did they make a change in the in the production year. That would seem really stupid to change the way the switch went in. Or they just made a mistake in the Aim.
