1972 corvette power steering hose
Old Nov 28, 2017 | 09:27 PM
mongoose87's Avatar
mongoose87
Default 1972 corvette power steering hose
Hello,
My power steering makes whining noises and is difficult to turn, when i turn the wheel while at a stop, so I am planning on replacing my power steering pump this weekend.
There is no way the issue could be coming from a bad PS cylinder or valve assembly, could it?
I thought it would be a good idea to replace all the hoses at the same time, with the pump being so cheap.
I see sets on Amazon marketed for 1980-82 corvettes, and from the picture they look to be exactly the same.
I'd rather order through them because of the free shipping that comes a bit faster, and the kit is a bit cheaper.
Can someone please tell me if they are exactly the same, and if not, describe the difference?
Thanks!
Old Nov 28, 2017 | 10:37 PM
mortgageguy's Avatar
mortgageguy
Go to Amazon and enter "Edelman 80118 power steering pressure hose" . Scroll down to "frequently bought together" for both hoses. Hope this helps. Says it is a fit for 1972 Corvette.
Old Nov 28, 2017 | 10:49 PM
CanadaGrant's Avatar
CanadaGrant
All the corvette vendors list both a different pump and hoses for an 80-82 so I doubt they would be a bolt on fit for your 72.
Old Nov 29, 2017 | 01:04 AM
revitup's Avatar
revitup
Try Rockauto. That's where I found the best price for the '77. $63 for the set including shipping, ACDelco.
Old Nov 29, 2017 | 12:54 PM
mongoose87's Avatar
mongoose87
Thanks all for the clarification. I ordered from Rockauto under the 1972 year for a pretty good deal cheaper than the other sellers.
Old Nov 29, 2017 | 03:51 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 1980-1982 hose set is different. It uses an o-ring on the pressure hose where the 63-79 hose set didn't. .
The 63-79 small block hose set I have, I'm not sure if it's cheaper but they are 54.99 for the set. https://willcoxcorvette.com/corvette...block-63-79-sb
Willcox
Old Nov 29, 2017 | 04:06 PM
HeadsU.P.'s Avatar
HeadsU.P.
Always ask the vendor what country of origin on the parts regardless of who you order from, via an email or phone call. Some of the cheapo's leak at the fitting coupler.
Old Nov 29, 2017 | 04:30 PM
NeverTooOld's Avatar
NeverTooOld
Originally Posted by mongoose87
Hello,
Thanks!
If the power steering pump is filled to the correct level and the belt is tight it should run quiet. But if it has been run too low on oil and the vanes and vane ring got damaged it will make noise. So check the oil level and belt tightness first before ordering any new parts.
To 1972 corvette power steering hose
