Leaking Master
Old Nov 29, 2017 | 06:46 PM
Tecdiverfl's Avatar
Tecdiverfl
Default Leaking Master
Pulled my master cylinder out to make room for my steering box removal and found a surprise. Looks like the master was leaking into the booster. I just ordered a new master and wondering if he brake fluid messed up the power booster.
Old Nov 29, 2017 | 08:04 PM
NeverTooOld's Avatar
NeverTooOld
I have never heard of DOT 3 brake fluid damaging a brake booster but the DOT 5 might damage it because it will severely swell the OEM brake hoses..
Old Nov 30, 2017 | 10:38 AM
MelWff's Avatar
MelWff
why would DOT 5 swell the OEM brake hoses? I have been using it for at least 20 years and nothing has happened to the hoses.
Old Nov 30, 2017 | 10:47 AM
silver74vette's Avatar
silver74vette
I do not think that you will have any internal damage to the booster. If it is working well I would clean it up and make sure it operates smoothly.
Old Nov 30, 2017 | 10:55 AM
Big2Bird's Avatar
Big2Bird
Do you have any back up for this claim?
Old Nov 30, 2017 | 11:12 AM
NeverTooOld
If you read my post again you'll see I didn't make any claim.
Old Nov 30, 2017 | 11:52 AM
revitup's Avatar
revitup
I'm still wondering why the master would have to come out to remove the steering box. My '77 box was easily removed, with pitman arm still attached, by just sliding the alternator out of the way.
Old Nov 30, 2017 | 12:33 PM
stingr69's Avatar
stingr69
Conventional DOT 3 is hard on paint but does not hurt rubber. DOT 5 is not hard on paint or rubber. The brake fluid will not harm rubber in a a booster.
Old Nov 30, 2017 | 06:29 PM
HeadsU.P.'s Avatar
HeadsU.P.
So now you are making a disclaimer?
Old Nov 30, 2017 | 10:51 PM
Tecdiverfl's Avatar
Tecdiverfl
Well popped out the vacuum grommet and put a flexible rod in with some paper towel on the end. The booster is loaded with brake fluid. No matter what I am taking it off this weekend.
Old Dec 1, 2017 | 07:43 AM
silver74vette
Sorry to hear that, probably worth replacing it. Looks like you get to remove my four favorite bolts....
Old Dec 1, 2017 | 11:05 AM
Tecdiverfl's Avatar
Tecdiverfl
How big of a PIA is it to remove the booster? I was going to remove the Drivers seat and use a swivel with a long extension
Old Dec 1, 2017 | 01:10 PM
hgoodwiniii's Avatar
hgoodwiniii
I know on my 76, it can be a pain to remove it and reinstall it. There's just not enough space in that floor board area to be able to move around to good even with the seat out;
To Leaking Master
