Trailing arm quick fix: Bubba or genius?
Old Jan 1, 2021 | 08:21 AM
  #81
Matt Gruber's Avatar
Matt Gruber
Default shims in(rt side almost done)
left 1 thin shim out, would rather start out a bit loose so no binding. Still have to rebuild caliper and put on shock and spring bolt.
OT i call her "drift girl" Been watching for years. She just had a dream come true- a chance to try out for a race team
HNY!
Can anyone tell if her speed was in KPH or MPH?
Old Jan 16, 2021 | 09:38 AM
  #82
Matt Gruber
Default Test drive
5 miles listening for rattles from the slightly loose TA's - NONE. (did make noise past 3 years).
1st hard right turn, perfect drift, no steering correction.
2nd, no drama, not enough throttle.
3rd near WOT sent it to 1 fishtail i let off; again no steering correction (happened too fast for me to react) and ended up exactly in my lane..
4th - thinking about #3, and the cold temps 51F i had enough testing for today.
Brakes work good, but seems to take more effort with o-rings.
Alignment seems OK, can take my hands off wheel for 5 seconds, at which time it tends to inch left. Good but not perfect.
