350 top end build
Old Dec 4, 2017 | 02:18 PM
Yellow1977's Avatar
Yellow1977
Default 350 top end build
Hey guys I have a 77 with an l 48 in it. I’m looking to make about 400hp when I’m done with it. The car currently has a 600 dual feed double pumper quick fuel, dual plane performer intake headers and duals with glass packs for mufflers. I also put a 2500 b&m stall In it. Now I was going to order a pair of promaxx heads (185cc, 64cc) with a comp cam (.490 lift) and an MSD RTR unit for it. (Links below) do you guys think this combination will produce 400 flywheel hp? Any opinions are highly appreciated thanks for your help!!http://www.jegs.com/i/ProMaxx-Perfor.../2168/10002/-1
http://www.jegs.com/i/COMP-Cams/249/K12-246-3/10002/-1
http://www.jegs.com/i/MSD-Ignition/121/8360/10002/-1
Old Dec 5, 2017 | 07:38 AM
NeverTooOld's Avatar
NeverTooOld
Not with the water pump, fan, power steering pump, and alternator attached.
Old Dec 5, 2017 | 07:41 AM
Dynra Rockets's Avatar
Dynra Rockets
400 hp where? at 4500 rpm or 6800 rpm?
Old Dec 5, 2017 | 11:29 AM
jim-81's Avatar
jim-81
In my not so expert opinion - 400 could be doable as long as compression, timing and carb setup are all good.
Old Dec 5, 2017 | 12:52 PM
Strokemyaxe's Avatar
Strokemyaxe
I agree with Jim. However, depending on the age of the internals, I'd be worried about the rings withstanding that high compression. What compression will you be shooting for?
Old Dec 5, 2017 | 01:00 PM
Strokemyaxe
Oh! I almost forgot... Welcome to the forum!!! How long have you had the corvette? Where did you get it? What's the story!
Old Dec 8, 2017 | 08:44 PM
96 lt-4's Avatar
96 lt-4
Maybe,maybe not.Depending on your rear gear I may opt for one size smaller cam.Probably be more docile to drive normally and still shred the tires when you nail it.
Old Dec 10, 2017 | 11:49 PM
Gunfighter13's Avatar
Gunfighter13
750 Carb, 190cc/64cc heads, MSD RTR is good. Cam: Xtreme Energy 284H Hydraulic Flat Tappet Camshaft Complete Kit Lift: .507"/.510" Duration: 284°/296° RPM Range: 2300-6500, 2500 stall converter is good.......10.5 compression......93 octane fuel....
Old Dec 11, 2017 | 09:07 AM
Krystal's Avatar
Krystal
400HP seems like a lofty goal for your motor and it's low compression starting point........but you can get close. Your L48 is awfully similar to the GM Base level Crate motor that was subject of this 3 part build and test.
http://www.superchevy.com/how-to/463...-engine-build/
http://www.superchevy.com/how-to/463...gine-build-ii/
http://www.superchevy.com/how-to/463...ine-build-iii/
Old Dec 22, 2017 | 04:42 PM
Yellow1977's Avatar
Yellow1977
Hey everyone sorry about the long reply time I accidentally double posted and was looking at the other thread! Thank you all for the input!!
I’ll be shooting for a CR of 9:1 and will also be adding roller rockers to the list!
Old Dec 22, 2017 | 05:44 PM
REELAV8R's Avatar
REELAV8R
Maybe and probably not 400 HP. At least not at any reasonable RPM.
The dish pistons on the L-48 are not good for any rasonable power production. They are cast pistons good for a steady 350 HP. Above that it's a gamble. No squish pad either so detonation may become an issue.
A FT cam is also a gamble, expecially the Extreme series. They have a propensity for wiping a lobe.
Roller cam with roller rockers, those heads for a roller cam with straight plugs (unless angled plugs is what you want), flat top pistons, refreshed bottom end, and then you'd be in the 400 HP range at around 5500 RPM. And it might actually last a while.
Old Dec 24, 2017 | 08:59 AM
Krystal's Avatar
Krystal
.......COMPLETELY...... well thought out reasoning in this post too.
Today is a LONG WAY from when those GM Budget priced flat tappet cam Crate motor build stories were posted. Those were done more than 20 years ago. As of 2017? There is really no good reason or argument that suggests any thing less than a roller cam motor is a good starting point.
To 350 top end build
