Pitman arm
Old Dec 6, 2017 | 08:55 PM
Tecdiverfl's Avatar
Tecdiverfl
Default Pitman arm
I am assuming this is not normal threads ??
Old Dec 6, 2017 | 09:26 PM
Greg's Avatar
Greg
Just another Corvette guy
Are you referring to the alignment marks? If so, those are correct and supposed to be there.
Old Dec 6, 2017 | 09:36 PM
Tecdiverfl's Avatar
Tecdiverfl
Look at the missing threads in first pic
Old Dec 6, 2017 | 09:59 PM
NeverTooOld's Avatar
NeverTooOld
The thick spline guarantees it goes onto the splined shaft (with a missing spline) in only one position So it's made like that for a reason.
Old Dec 6, 2017 | 10:16 PM
Greg's Avatar
Greg
Oops, I see it now. Was on my hand held and the pics were too small to see it before. Yeah, something funky there but I'm pretty sure it would still work fine once tightened.
Tecdiverfl's Avatar
Tecdiverfl
I understand the think and thin splin. In the first pic there is about a 1/4 on spline missing on about 1/3 of the shaft
Old Dec 6, 2017 | 10:25 PM
CanadaGrant's Avatar
CanadaGrant
You are correct. The double spline is there and is for alignment on the shaft but those splines are really badly chewed up or rusted out, especially in the second pic. I would replace the arm and check the shaft at the steering box to see what's up there. I think a new arm is only about 60 bucks.
Old Dec 6, 2017 | 10:46 PM
CA_WxMan's Avatar
CA_WxMan
On my cars ('71 & '75), the pitman arm doesn't fully engage the splines on the shaft.
This may have been the case on your car as well, and then the portion that was not engaged may have developed enough rust to eat away some of the exposed splines.
It's just a theory, but I can't really think of another reason for it to be worn or corroded away like that.
Old Dec 7, 2017 | 01:46 AM
Greg's Avatar
Greg
Old Dec 7, 2017 | 08:44 AM
GTR1999's Avatar
GTR1999
Marty
The sector splines are tapered so you get an interference fit, as mentioned those were probably exposed to the elements over time- although the lockwasher and nut would have cover the opening of the arm. Used PS arms are about $40. #383 is for PS, #451 for manual. I rarely have to replace arms but they do wear at the tapered hole and some get bent in accidents and never picked up on.
Old Dec 7, 2017 | 02:50 PM
Tecdiverfl's Avatar
Tecdiverfl
Looks like when my car was restored they used the wrong pitman arm. Car had PS but an arm from a manual car.
To Pitman arm
