I changed machine shops for my big block project and I told them I was planning on putting the 496 eagle rotating assembly in my block and they recommended using scat. I wanted to get your guy’s take on the two and what your experiences have been. Thanks guys you are always a huge help in my decision process so thanks!
Kind of depends on your budget. There are better sources than both of those, but the best stuff doesn't come without a price tag. Just going to be a driver, either will probably get the job done for you. The shop which turns cranks for me often turns the eagle cranks 0.010/0.010 out of the box. Have had some that had the rod journals not parallel with the center line of the mains.
What are some better brands to use? I guess my problem is I’m trying to localize all my stuff to summit racing for convenience as I can add it to my wish list and adjust or rearrange as needed or when I change my mind.....which is at least once a day at this point lol
What do you plan to use the motor for? As Indiancreek mentioned, there is a price tag associated with high end parts that are intended for racing use and extreme conditions for extended periods of time. Keep in mind that OEM parts properly installed last 100K miles in cars that are daily drivers with occasional full throttle use.
It will honestly be street with occasional strip time but probably rarely
In that case an OEM forged crank would be as good or better than buying the import. Like ronarnt said, many OEM raced many passes in the early days. Spend the extra money for a good balancing job. The bottom end if your durability. Good crank rods and pistons and your engine should last a long time. It's difficult to swallow the cost of a good set of rods (like a set of Olivers) but that is money well spent. Probably over kill for your intended use.
Guys put alum heads, cam, 900 holler on cast flat top 3/8 rod bolt bottom ends. Put them in boats and run them at 3/4 throttle constantly. In a car, 7 seconds at full throttle and you are a danger to yourself and others. In a boat, 30 seconds at full throttle and you are starting to come up to speed. 70 mph takes 500 hp in a fast hull. Only thing boats don't see is 7000 rpm. But to make a valve train produce power above 6k in a big block takes a bunch of money.
Go with a Scat setup and don't look back. Stay away from the Eagle stuff. Would probably be fine, but Scat has been very good and it is just not worth the risk.
Callie's is definitely good stuff. The "regular" Callie's cranks are the same forging on BBC. The price difference is the amount of machining and lightening that occurs. The raw forgings came from Japan last I heard. I've got one in my motor and it's held up well.
The Compstar line is the Chinese import versions to compete with SCAT, Eagle etc. Still good quality.
The machine work by Callie's is some of the best out there out of the box. They also do crank machining for Howards I believe.
I've got Oliver rods in my engine and they are incredible. I've heard through the grapevine there may be new owners and things might have changed recently but don't know for sure.
I've been to SCAT's machine center in CA and was given a tour by the owner. They do LOTS of the OEM high performance parts used in the best crate motors and higher end race parts. I ran SCAT rods in mine for years.....still have them. Nothing wrong with them...bearings always looked perfect...just changed to the Oliver's with ARP 625 bolts considering how I run the thing.
JIM
Callie's is definitely good stuff. The "regular" Callie's cranks are the same forging on BBC. The price difference is the amount of machining and lightening that occurs. They raw forgings came from Japan last I heard.
