TKO 600 .64 vs .82
Old Dec 19, 2017 | 09:38 PM
jb78L-82's Avatar
jb78L-82
Originally Posted by Tiger Joe
Not a vette, but i run the .64 OD behind my 496 in my 67 c10. 3.73 gears with 29” tall tires.
I’m glad I don’t have the .82. Big block torque means if i hit an open back winding road I can chug along in OD. Most times I run up to 4th on all the back roads and leave 5th for the 4 lanes. If you only ran at 60-65 you might want the .82 but let’s be honest every drives 70-75.
Honestly it’s the best mod I ever did to the truck
Your experience again predicts what i have been saying..BB 496 can take any OD such as .64 due to the torque and coupled with your comment that most cars today are cruising 75-80 mph on the highway which I agree would be ideal, not .82.
I just drove a rental Nissan Rogue today from Nashville to Chattanooga TN at a consistent 80-85 for 200 miles just today. ,82OD for most applications would NOT be enough at those speeds to keep the revs lazy....
Old Dec 19, 2017 | 09:48 PM
lakemg's Avatar
lakemg
The 0.64 will be like driving the TH400 in 3rd gear with a 2.15 rear end ratio.
0.64 x 3.36 = 2.15
The 0.82 will be like driving the TH400 in 3rd gear with a 2.76 rear end ratio.
0.82 x 3.36 = 2.76
Old Dec 19, 2017 | 09:49 PM
Priya's Avatar
Priya
Originally Posted by jb78L-82
GM F body V6 cars with the WCT-5 speeds came with the .75 OD again due to the lower torque of the V6 engine. V8's came with .63OD which to me is the ideal street V8 OD.
Would you say that with a 3.70 rear gear?
Old Dec 20, 2017 | 01:44 PM
toddalin's Avatar
toddalin
I have the 0.64 with a 3.70 rear end. Anything less than 3.70 needs the 0.82.
The 5 - 4 shift coming off the freeway is pretty extreme with the 0.64.
Old Dec 20, 2017 | 02:23 PM
Priya's Avatar
Priya
Originally Posted by toddalin
I have the 0.64 with a 3.70 rear end...
That's what I'm thinking will be the case with my 3.70 rear end and the .67 fifth gear. I think a .75 fifth would be the best compromise as the .82 fifth wouldn't provide enough rpm drop for cruising at 60 mph in fifth and the .67 fifth might be an undesirably low rpm for crusing at 60 mph in fifth.
Old Dec 20, 2017 | 03:52 PM
SteveG75's Avatar
SteveG75
Which is why I went to the T-56 Magnum with both a .80 (5th) and a .63 (6th) OD.
Old Dec 20, 2017 | 04:21 PM
Priya's Avatar
Priya
I think I'd still want something in between those two gears. But I'll see when I ever get the five speed installed.
Old Dec 20, 2017 | 05:26 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Yep! With a 4.11 it is 10.93 to 1 first gear, close ratios all the way through and 2 overdrives. 6th gear is like a 2.59 rear end. Best of both worlds. Making it fit easily is another story.
Old Dec 20, 2017 | 05:41 PM
Priya's Avatar
Priya
How do you find that 10.93 to 1 first overall gear ratio? My five speed has a 3.27 first and with my 3.70 rear end its a 12.1 overall first gear ratio which I worry might leave me with very little time in first gear before I hit a 5000-5500 rpm or so shift point.
Old Dec 20, 2017 | 05:51 PM
63mako's Avatar
63mako
Redline/shift point 6500 RPM is
1st 47 MPH.
2nd 70 MPH
3rd 96 MPH
4th 125 MPH
5th 156 MPH
6th 199 MPH
2500 RPM is 60 MPH in 5th and 2600 RPM is 80 MPH in 6th. 2500 is the cruising sweet spot with my cam
Old Dec 20, 2017 | 06:05 PM
Priya's Avatar
Priya
1st 47 MPH.
2nd 70 MPH
3rd 96 MPH
4th 125 MPH
5th 156 MPH
6th 199 MPH
So, judging by that if my redline is 5000 rpm I'd be shifting at 35 mph into 2nd.
Old Dec 20, 2017 | 06:26 PM
OldCarBum's Avatar
OldCarBum
That's why I'm trying to stay with a 3.36 rear end gear.
I'm not thinking red line shifting, I'm looking at street driving, twisting roads and highway cruising.
A 6 speed would be awesome, but cost and fitment are issues.
I've wanted to jump on the purchase of the SST kit before the new year and get their holiday, year end specials, but it looks like I might just wait and piece this together on my own a little at a time to save a little $$$
Old Dec 20, 2017 | 06:45 PM
  #33
Priya's Avatar
Priya
Any of the five speeds you can currently get aren't going to have a 3.27 first gear like my Keisler RS400 does. If I remember correctly ones like the tremec have a 2.6 - 2.8 first gear or so. My motor is going to have tuned port injection which limits top rpm. You are not likely going to have the same concerns I do with having to shift to second too soon if you have a 3.70 rear end gear.
Old Dec 20, 2017 | 07:25 PM
  #34
OldCarBum's Avatar
OldCarBum
Exactly.
That's why I'm looking at the TKO 600 with the .82 and 3.08 rear gearing.
At 65 mph in 4th I'll be at 2470 rpm and in 5th 2025 rpm.
Around town will be tame and roll on at 65+ speeds will be hot with the operating range of my cam at 2000-6000 rpm.
The 496 at 600+ ft lbs torque should still be plenty of fun around town even with the 3.08's.
With a 3.36 I'll only be at 2694 rpm in 4th at 65 mph and 2209 rpm in 5th at 65 mph.
Old Dec 20, 2017 | 07:49 PM
  #35
Priya's Avatar
Priya
My car with the 3.70 rear and present close ratio 4 speed (2.25? 1st) gives about the same overall first gear ratio you'd be looking at with the TKO and the 3.08 rear gear. I find it annoying to get moving as the rpm is too low and if I don't rev the motor more than I'd like and slip the clutch the car shudders to a start. I realize you'll have far more power than my stock small block, but I think if I was you I wouldn't like that overall first gear ratio.
Old Dec 20, 2017 | 07:58 PM
  #36
jb78L-82's Avatar
jb78L-82
Exactly.
With a cam operating range from 2,000-6,000 RPM I can understand that you need to keep the revs above 2,000 RPM and you would need a .82OD as long as the motor does not run well under 2K. With a 496 BB that is too bad since with a motor that big, I would think you could cruise at 70 MPH all day long at 1,500 RPM...
With my 355 L-82 with a cam operating range of 1,500-5,600 RPM, the motor can run all day long at 1,500 RPM on the highway at 80 MPH and it would be perfectly happy. My 10C6Z06 cruises at 80 MPH at 1,750 MPH....which is perfect and gets 28 MPG doing it. Ill take 1,800-1,900 RPM @ 80 MPH all day long with the 355...That is what OD is for......
Old Dec 20, 2017 | 08:00 PM
  #37
drwet's Avatar
drwet
Many years ago I built an S-10 with a small block, 3.70 rear gears, and 3.27 first gear. Great truck, but first gear just didn't work. The truck originally had a 2.8 V6 - hence the deep first gear. Pretty much useless with a V8. Better off starting out in second gear in street driving. 12:1 is way too deep a gear ratio. My '79 has the TKO 600 with 2.87 first gear and 3.55 rear end for a final drive ration of 10.19:1 which is just about perfect.
To TKO 600 .64 vs .82
Old Dec 20, 2017 | 08:07 PM
  #38
Priya's Avatar
Priya
Yes, at the time I wondered if the 3.27 first gear was too much for my 3.70 rear end but Keisler told me it would be fine. I wondered at the time if I should buy the RS600 with the 2.80 first gear instead and I've been thinking maybe I made a mistake ever since. Although if I'd have ordered the RS600 which they were way behind on production I may have got nothing and lost my $3000. I think it will be okay with the 6000 rpm red line on my stock L82 but I'm having my doubts when I convert to tuned port injection and the motor reaches top rpm at 5k or so.
Old Dec 20, 2017 | 08:28 PM
  #39
flyeri's Avatar
flyeri
I can't completely agree with this. Yes it is a drop from 4th to 5th. However the OD is not meant to be an acceleration gear. It is a cruising gear. Besides that, with 3.55 gears it will pull to 120+ in 4th at 5400rpm. You really need a drop after that. If you are racing the .82 would be better.
Old Dec 20, 2017 | 08:42 PM
  #40
jb78L-82's Avatar
jb78L-82
This is correct!^^^^^^^^^^^^^^^^^OD is NOT an acceleration gear on the street...designed for lazy motoring, low revs, reduced engine wear, and increased MPG. I am amazed at the different opinions on this subject but that is why there is a forum.......
