77 C3 power steering
Old Oct 10, 2002 | 08:31 PM
myyellowc3's Avatar
myyellowc3
Default 77 C3 power steering
Hello all,
I am a first timer. :flag I have just ordered a rebuild kit for my power steering control valve. Does anyone know how difficult that will be ? :smash:
Old Oct 10, 2002 | 09:45 PM
FeedVaal's Avatar
FeedVaal
Default Re: 77 C3 power steering (myyellowc3)
Hey! Beauty car... On a scale of one to ten, its about a seven. If you haven't already, check out http://www.corvettefaq.com and look under steering for a great how-to article.
:seeya
Old Oct 10, 2002 | 10:08 PM
myyellowc3's Avatar
myyellowc3
Default Re: 77 C3 power steering (FeedVaal)
Thank You for the info. I will check it out. :D :chevy Did check the site out and printed off some instructions that will make the job a little easier.
Rich
[Modified by myyellowc3, 2:28 AM 10/11/2002]
Old Oct 11, 2002 | 09:26 AM
Edzred72's Avatar
Edzred72
Not that difficult at all. Carefully follow the directions, spread your parts out in order of their disassembly, and go slow. Balancing the valve after install is very important. GM service manual has the procedure. I just did mine and it will make a world of difference. Good Luck.... :cheers:
Eddie
Old Oct 11, 2002 | 12:56 PM
myyellowc3's Avatar
myyellowc3
Default Re: 77 C3 power steering (Silvr77)
I was wondering if yours was leaking fluid from there before you removed and rebuilt it? :)
Rich
Old Oct 11, 2002 | 01:36 PM
HEARTBEATUSA's Avatar
HEARTBEATUSA
Welcome to the forum! Mine was literally pouring out of the valve, I bought the rebuild kit but upon inspection of the internal components, I opted to replace it (spool was corroded) If you follow the instructions it should go easy! If you get in trouble the forum will help. Good Luck
Old Oct 11, 2002 | 01:39 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: 77 C3 power steering (HEARTBEATUSA)
Put two repair kits, both worked for several months then leaked again, bought a new PS valve then a rebuild both worked and then leaked after 6 months, still elaks but very small amount, f@#$k it.
:jester
Old Oct 11, 2002 | 10:11 PM
s79vette's Avatar
s79vette
Default Re: 77 C3 power steering (Cali,77,L-82)
Just finished with my steering last nite. Got recond. valve and kit for cylinder.
Drove it around tonite a bit and no leaks. Still have to put some grease on ball joints. Tonite was just a test drive for hose fittings and seals. Follow directions on balancing cylinder with shaft disconnected. it will not be balanced no matter what the retailer says, they all have to be adjusted. Steve
Old Oct 12, 2002 | 12:16 AM
myyellowc3's Avatar
myyellowc3
Default Re: 77 C3 power steering (s79vette)
Still waiting for my kit to come in. I was wondering if the balancing process is time consuming, or overwhelming? :crazy:
Rich
To 77 C3 power steering
