Given it was 70 degrees today, decided it was time to start the refurb of my 78s brake system that would include replacement of calipers, hoses and master cylinder.
First was to clean out the brake lines with denatured alcohol. Gravity worked nicely on the front lines to drain both lines. Once I got to the rears, the right side rear would not drip. Went to the left side (drivers) and it drained as expected, emptying the M/C cylinder of denatured alcohol.
Went back to the right side and used a suction pump...and still would not pull fluid through the line. No wonder I had brake failure when I started this project.
Where's the blockage...proportioning valve? BTW, the caliper pistons had heavy corrosion built up within those cylinders. Thus the calipers became core exchanges.
You could take the bleeder screw all the way out. Spray some brake cleaner in the caliper threaded orfice and try again. I bet the blockage is right behind the bleed screw from corrosion.
If your bleeder screws don't have the dust caps the hole in the bleeder screw will plug solid. If that's the case just use a piece of stiff mechanic's wire or drill bit to dig the dirt out.
So now, you have to back-track even further over to the junction fitting for the left rear caliper. That fitting might be the issue. You said left rear flows, right rear does not.
Always that chance that a brakeline was pinched from a floorjack or jackstands or something.
After removing the cut rubber hose from the right rear block...gravity worked and denatured alcohol emptied from the M/C. So the blockage was in the host from the block.
I'll use air pressure to blow those lines out before reassembly of hoses and calipers.
