383 engine and distributor
Old Dec 24, 2017 | 01:45 PM
jcorvette72's Avatar
jcorvette72
Cruising
Default 383 engine and distributor
ive been reading about melonized gear on the distributor
some engines have roller rocker camshaft. how do i determine if i need a melonized distributor gear or not.
thanks for any help
Old Dec 24, 2017 | 04:13 PM
gkull's Avatar
gkull
first off rockers, lifters, and cams are three separate items. Roller lifters means that they have a rolling wheel riding on the cam shaft. Roller rockers are a type of rocker.
99.999% of all distributers sold have melonized gear. Only billet steel cam shafts require an alterative gear
Old Dec 24, 2017 | 05:36 PM
PainfullySlow's Avatar
PainfullySlow
thanks for any help
Most of the time the camshaft manufacturer will state whether or not they need a specific distributor gear.
For example, the current Comp retro roller cams are recommending a synthetic gear.
Old Dec 24, 2017 | 05:41 PM
derekderek's Avatar
derekderek
Most modern roller cams, unless they have a pressed on iron gear, need the melionized gear. Comp recommending synthetic probably needs the hard gear, but comp would rather you were a member of the distributor-gear-of-the-year club and didn't tear up their cams gears...
Old Dec 24, 2017 | 10:32 PM
jcorvette72
Cruising
thanks everyone.....thats a great help....i wlll go with the distributor tha was put in the engine.
To 383 engine and distributor
