Crankshaft dowel pin
Old Dec 26, 2017 | 09:54 AM
drwet's Avatar
drwet
Default Crankshaft dowel pin
The crankshaft in the 383 I am replacing has a dowel pin in the crankshaft flange that engages a hole in the flywheel. The Scat crank in the new 427 has the hole for the dowel but no pin. I looked at several of the engines in my collection and some have the pin, some don't. I'm assuming the pin needs to be there, but I can't seem to find a source for the dowel pin. Am I searching for the wrong term? Where can I get a new dowel pin?
Old Dec 26, 2017 | 11:01 AM
NeverTooOld's Avatar
NeverTooOld
You can get one from a crankshaft that is beyond turning. Any automotive machine shop should have several lying around.
Old Dec 26, 2017 | 11:04 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Try googling small block chevy crankshaft dowel pin.
Old Dec 26, 2017 | 11:23 AM
redvetracr's Avatar
redvetracr
unnecessary
Old Dec 26, 2017 | 11:42 AM
Duke94's Avatar
Duke94
Originally Posted by redvetracr
unnecessary
Measure the hole size then go to McMaster Carr website or your local Ace Hardware, both will have what you need.
Old Dec 26, 2017 | 11:56 AM
derekderek's Avatar
derekderek
I doubt you could put crank on wrong. The 6 bolts only go in in 1 orientation. Wheel centers on crank hub. Dowel only provides a couple thousandths of left-right orientation. You can punch dowel out of your old crank if you don't wanna run around town for one. Or do without..
Old Dec 26, 2017 | 08:53 PM
PAmotorman's Avatar
PAmotorman
some stock chevy cranks have the dowel pin so you can't install the stock flywheel in the wrong orientation where the flywheel is part of the balance like a 400 chevy
Old Dec 26, 2017 | 11:24 PM
NeverTooOld
Call Scat and see if they want the dowel pin installed. Maybe your crank is balanced for running without the pin and you would upset the balance if you used one.
Old Dec 26, 2017 | 11:36 PM
derekderek's Avatar
derekderek
you can't put the flywheel on wrong, dowel pin or not. it is not a round symmetrical bolt pattern.
Old Jan 2, 2018 | 10:48 PM
ezobens's Avatar
ezobens
While the pin may not be necessary, it does serve a purpose or it wouldn't be there.
I prefer to have it in place to prevent the flywheel from turning on the crank and placing unnecessary side load on the flywheel bolts.
Just the engineer in me- Your mileage may vary.
Old Jan 3, 2018 | 04:02 PM
Surfer69's Avatar
Surfer69
I had same issue. Not necessary especially on internal balanced. 0.02
To Crankshaft dowel pin
