Recommend after market manifold?
Old Dec 26, 2017 | 03:43 PM
Byzantine's Avatar
Byzantine
Default Recommend after market manifold?
I'm thinking of switching out my 3x2 manifold for a four barrel manifold on my 1969 Vette. Can anyone recommend a manifold that will fit under my stock, low profile 427 hood?
Old Dec 26, 2017 | 03:51 PM
roscobbc's Avatar
roscobbc
Edelbrock Torker 2 (if the engine is a big block)
Old Dec 26, 2017 | 04:04 PM
Byzantine's Avatar
Byzantine
The motor is the original 427, 3x2, 400hp.
Old Dec 26, 2017 | 04:47 PM
roscobbc's Avatar
roscobbc
Torker 11 is the only 'performance' inlet that will fit under stock BB hood. I say 'performance' inlet in inverted comma's as you'll find few people who consider it a performance manifold compared with other current choices - however these will not fit under BB hood......so where do you do with this? - I'd have thought that keeping the 3 x 2 no's was the best thing?
Old Dec 26, 2017 | 05:37 PM
69ttop502's Avatar
69ttop502
The old LS6 manifold will fit. My car had one on it when I bought it with the stock big block hood. It was used on the 71 Corvette LS6. It is a square port manifold however, and you have oval ports. May work ok. Here is a link to one for sale. Works good for what it is.
https://www.ebay.com/i/321910227533?...D1401791550426
Old Dec 26, 2017 | 05:58 PM
Mooser's Avatar
Mooser
3947801 which is the 69 427/390 oval port for Qjet will also fit
M
Old Dec 26, 2017 | 06:07 PM
Byzantine's Avatar
Byzantine
I've had this car for a little over 30 years now, and every time I take it out, I have to check for leaks, be it fuel lines or front bowls. There is nothing more iconic than to lift the hood and see that air cleaner sitting on top of three duces. If I were to switch over, I just want to know what manifold would fit under the hood.
Old Dec 26, 2017 | 06:35 PM
NeverTooOld's Avatar
NeverTooOld
The Edelbrock "Torquer" intakes are intended for high rpm use and will give up a lot of low end torque.
Old Dec 26, 2017 | 10:04 PM
ddawson's Avatar
ddawson
I used the LS6 when I built the 496. Make sure to use the LS6 gasket.
You may also need a spacer under the carb.
https://photos.smugmug.com/Corvette-...dcvdgsa-X3.jpg
Old Dec 29, 2017 | 09:10 AM
Byzantine's Avatar
Byzantine
Thanks for all the great replies. I'm in no hurry to change out the 3x2's, but it's nice to know what will fit under the hood.
Old Dec 29, 2017 | 07:06 PM
Crimson Thunder's Avatar
Crimson Thunder
The really cool (but expensive) solution would be to convert to fuel injection. There are a couple of companies the make 3x2 throttle body systems.
To Recommend after market manifold?
