73 dash lamps
Old Dec 27, 2017 | 05:16 PM
grumpy73's Avatar
grumpy73
Default 73 dash lamps
Hey guys, I need some help with the instrument lamps on my 73. None of them burn, I checked the fuse which was good (replaced anyway) and checking the voltage I have 0 volts on either side of the fuse. The head light indicator works and the kick panel lights come on when I turn the head light switch to the full left position. Where do I check next?
Old Dec 27, 2017 | 05:23 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Try rotating the dimmer on the headlight switch to full brightness.
Report back and we'll go from there.
Old Dec 27, 2017 | 05:34 PM
Peterbuilt's Avatar
Peterbuilt
Default Is the tail lamp fuse good?
The 'TAIL LAMP' fuse sends power to the instrument fuse.
Old Dec 27, 2017 | 05:52 PM
grumpy73's Avatar
grumpy73
Checked all the other fuses and they have 12 volts across them. Tried rotating the switch from full dim and to full bright, with no change. According to the wiring diagram the inst lights are on the small 5amp fuse at the bottom of the panel.
Old Dec 27, 2017 | 06:09 PM
Peterbuilt's Avatar
Peterbuilt
Next try a jumper from the 'courtesy light fuse' to the 'instrument light fuse'.
If the dash lights go on then the rheostat in the head light switch is bad.
Old Dec 27, 2017 | 07:10 PM
grumpy73's Avatar
grumpy73
Ran a jumper from the battery to the fuse and the lights come on except for the tach and speedo
Old Dec 28, 2017 | 07:23 AM
Blue73Shark's Avatar
Blue73Shark
Fuse may be bad or there is corrosion at the holder. Also check wire connections to the holder. Take out the two lights that do not work and test them. Replace if burned out. Otherwise, check for corrosion/loose connection at the sockets.
Fran
Old Dec 28, 2017 | 09:55 PM
Peterbuilt's Avatar
Peterbuilt
That's interesting!
Pulling the light switch to the first or second click sends power on the GREEN wire into the fuse.
Power comes out of the fuse on GRAY wires and sends power to ALL the bulbs.
Could you have corrosion where the GREEN connects to the switch or at the fuse connection?
Could you have a break somewhere on a GRAY wire?
Have all the bulbs lit up ever before?
Wild guess, are all the bulbs bad?
Old Dec 29, 2017 | 10:38 AM
lvmyvt76's Avatar
lvmyvt76
GOUND wires good???? They have to be hooked up for lights to work, the dash does not ground any bulbs unless the ground wires(usually black in color) are hooked up.
Old Dec 29, 2017 | 07:09 PM
rberman999's Avatar
rberman999
Since your instrument lights work (with the exception of speedo and tach) when running a positive wire to the fuse that tells you your ground is good to you "gauge plate" ( the gauges are mounted to a metal mounting plate) and the wires are good to each bulb that lights. So you have a power problem, either at the headlight switch or out of the headlight switch. I can speak to the gauge lights only as I've got mine working (not speaking to tach or speedo). The lights for my 73 have a single gray positive wire to each socket, ground is made from the socket tangs that hold the socket into the metal gauge plate which is grounded. So, either wiring issues from switch to fuse, switch issue or input issue to switch. Your tach and speedo could be as simple as burnt out lights or something related to the gauge lights. Lots of luck, Russ
Old Dec 29, 2017 | 10:05 PM
grumpy73's Avatar
grumpy73
OK goys tomorrow I am pulling the head light switch and running a 12 volt source to the green feed and see if we get lights. My assumption is if the lights come on it points to the switch if not the fuse block.
Old Dec 29, 2017 | 11:10 PM
Peterbuilt's Avatar
Peterbuilt
That sounds like a good plan and thanks for the follow-up.
Make sure you reconnect the vacuum hoses correctly.
Old Jan 1, 2018 | 12:12 PM
grumpy73's Avatar
grumpy73
OK changed the switch and created a set of new issues. the dash lamps come on but burn all the time unless you dim the switch as far as it will go. makes no difference if the lights are on or not, Also the tail lights burn all the time.
Old Jan 1, 2018 | 08:43 PM
rberman999's Avatar
rberman999
Grumpy73,
Sounds like a possible issue with your new head light switch. If the switch is not internally wired correctly or the switch is not the correct one ( I remember two different switches being listed for early VS later C3's) then that could be an issue. Did you try out the new switch before you re-assembled things back together? Where did you get your new / different switch from? Might be worth talking with the supplier about your issues. I changed my headlight switch but used a NOS Delco I bought off eBay. It was fairly reasonably priced (paid about $70 including shipping) tried it out before fully re-assembling and then buttoned things up. The new switch fixed my gauge lighting issues. Keep updating with any new developments. Lots of luck, Russ.
Old Apr 5, 2020 | 11:58 PM
Perry Paulsen's Avatar
Perry Paulsen
Navigator
Default hi my name is perry having trouble
2005 c6 hazard light will not go off inless I disconnect the batterie switch in car is off
To 73 dash lamps
